Question about LG DBRH197H DVD Player/HDD Recorder
After seven months of usage,it started ignoring reading all types of discs i.e display says no disc.
I had the same problem with this unit. I replaced the DVD burner and all was fine.
Posted on Feb 10, 2011
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
My WII will not read any disk and we do not have a menu. All it will say is unable to read disk.
Unable to Read the Disc / Disc Could Not Be Read Situation:
  • System displays either error message "Unable to read disc" or "Disc could not be read"
What to do:
  • This message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • If the Wii console is laying flat, verify that the system is not placed upside-down. The game disc slot should be above all three buttons and the SD Card slot.
  • Verify that the disc is being inserted properly.
    • If the console is placed vertically, the disc label will face to the right. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically (learn more)
    • If the console is placed horizontally, the disc label will face upwards.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Situation Not Resolved:
  • If only one Game Disc displays this error message, it will need to be replaced. Click here for Game Disc replacement options
  • If the error is occurring with most or all Game Discs or all of one type of game, then this indicates a problem with the system. The console and one or two example discs will need to be sent in for repair. Click here to begin the repair process.
Dec 25, 2011 | Nintendo Wii Console
My hp wont read dvd-rw. am i not using right type of disc or what could it be.
first is check if dvd or just cd rom u have..if its is cd rom definitely you cannot read any type of dvd disc.if it is a dvd rom, how old is you dvd rom?all dvd rom even cd rom even its is a writer or reader only have limitation on the lens usage.maybe it reaches the limit of usage.if thats the case you have to replace or buy a new one..
Jul 11, 2011 | Computers & Internet
LG RH1888H displays 'no disc' after inserting any type of disc.
Hi.
The problem is usually caused by dirty lens. Follow the indications in this link. I wrote the article to answer to the same common problem:My player does not read disks.
Cleaning lens is the most common fix for the problem. If that does not work, then the internal drive must be replaced.
Regards.
May 08, 2010 | LG RH1999H DVD Recorder/HDD Recorder
Ps3 wont read disc
First you need to verify that all types of discs won't read. there are 3 types that a ps3 will play CD, DVD and BluRay. If none of them work then your laser is either dirt and needs to be cleaned or is bad. If say dvd and cd works than the BluRay part of the lens needs to be calibrated which requires takign the system apart an voiding warranties.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD player locks up, won't read discs
its about time you get a new DVD Player...What type is it??? if it is a expensive one it is probably worth getting repaired but if it is a cheapy..then throw it away coz its not even worth looking at...there are the biggest pain to fix!! Best solution is to buy a new one!
Aug 11, 2009 | Televison & Video
DVD-Player not reading discs.
Well if it happens to every disc, then you know its the discs that are the problem. It should be the DVD player. Check if you plugged in the yellow, white, and red plugs accordingly. And also try blowing inside the DVD player, to blow away any dust that might be fogging the disc from beiing read.
Good Luck!!!! Rate Please!!!!!
Jun 13, 2009 | Philips Televison & Video
Cant play new discs on LG RH177
Try using the regionfree hack....it might work
1 open the tray in dvd mode
2 push 0 seven times.
3 it will ask you if you want to become region free just
push yes
Jaysamuel
Jan 18, 2009 | LG RH177 DVD Recorder/HDD Recorder
LG DBRH197H DVD Player/HDD Recorder Logo
49 people viewed this question
Computer Repairing
Computer Repairing
