Question about Brother IntelliFax-2820 Laser Fax
Baud rate I want to make sure my fax is set up the best way with my vonage telephone service. They said the baud rate should be low 9600 BPS. How do I change this and is this true and is there anthing else I should know. Sincerely, Gregg Smith greggbsmith@gmail.com
  • Anonymous Mar 31, 2014
    I need to change baud rate to 9600
    Scholar:
  • 47 Answers
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
Basic reduces the modem speed to 9600
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps.
Posted on May 28, 2008
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Need to know what bod rate is on my fax
older fax machines used a 9600bps baud rate, meaning a transfer rate of 9600 bits per second. a Bit being an 7th/8th of a byte. The newer machines can transfer at 14400bps, which older machines can not read, as its too fast. thats why they asking the BAUD rate.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I need to change a baud rate to9600 for telephone line. can you direct me please.
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
and MFC-7225 only.
Note
14400 bps.
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
MFC 8440D FAX VOIP
You should change the Baud rate to 9600 on the machine. This should correct your issue.
Also call vonage and they have some settings they can modify to improve performance.
Mar 31, 2008 | Brother MFC-8840D All-In-One Laser Printer
Baud rate
# Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
# Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options until ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
Mar 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
Brother IntelliFax-2820 Laser Fax Logo
1,781 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
