Question about Bosch Washing Machines
I am handy with mechanical stuff, and can't afford a repairman for our 9- yr. old Bosch Axxis WFK 2401 washer. So I could use a repair/service manual, if there is such an animal out there, and I'd just buy the parts myself and give it a go. I sure could use some help in finding it. Thanks for the help, Fred Hagen Miami FL
  • fredhagen Oct 07, 2010
    Hi, thanks for offering to help. We were in the process of washing a bathmat-type cotton rug around 2' X 3' in area. The mat gets extremely heavy when it is soaking wet, and tends to get off-center at the beginning of a spin cycle. We had the spin speed set at 400. As soon as the spinning began, the washer gave out a loud bang. When I managed to open the machine by setting it to "drain", I noticed that the gray rubber sealing ring behind the door had twisted out of its normal place. I suspect that the fix is pretty simple, but have no parts catalog or service manual to go by. Maybe I can do the repair without them, but I would feel a lot better if I had them.
    Let me know what else you need from me. Thanks again.
    Fred H.
    Genius:
  • 1,416 Answers
Fredhagen can you please come up with what the problem is like for proper solution.
I'm waiting for your comment.
Thanks.
Posted on Oct 06, 2010
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
I have a Bosch washer model WFK 2401 and I need a new pressure switch. The repair company I'm dealing with says that they can't get the part from Bosch any longer. Do you have any suggestions for...
We own a Bosch- probably nearly 20 years old. I manged to get the parts I needed- but we live in France and I buy on-line from the UK!
I would go onto the Bosch site. You will probably find spares suppliers from which to inquire. Also I'm sure you could query the Bosch site directly.
I'm not criticizing your repair company but I will be very surprised if the part was not available from somewhere.
Good luck,
John C
Feb 09, 2011 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
We have a Bosch WFK 2401 that is approximately 8 years old. I am not sure what cycle it was on when all of a sudden a loud noise started coming from the washer. Sounded like a gear stripping. A loud...
Check to see if inner drum is loose indicating bearing problem..Also check two springs on top of tub evident with lid off they can snap/ good luck
Sep 29, 2009 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washing Machines Logo
56 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
