Question about Canon PIXMA MP830 All-In-One InkJet Printer
Every time I print it looks like it is going to work and then it says "printer offline"
    Sergeant:
  • 157 Answers
Here try out these steps. The steps are for Windows XP but its almost same in Higher
  • Go to control Panel.
  • Now Click on Printers And Hardwares.
  • Now you will find the printers. You just need to give a right click on your printer icon and make it online.
If this solution dosent work for you leave a comment i will suggest you some more solutions.
If you like the post then please leave a feedback and rating.
Thanks in Advance
Posted on Oct 06, 2010
Printer is offline
Hi, turn it's power on. be sure the usb/data cable is connected to the cpu, if still not, remove the printer's adapter and connect it again, power it up again. if not still online, restart your pc.
When you want to print a document, you choose print and select your favorite printer but nothing happens. You look at the printer menu and see the pesky printer offline message and instant frustration. The task of the moment is going from offline to online. With creativity and patience, you'll have your printer back online in no time.
Instructions
Attempt to set the printer to online. This may not often work but it's the first action to take. Go to "Settings" and then "Printers". Right click on the "Printer" and select "Use Printer Online". Test the printer to see if it now prints.
Clear any print jobs. Double click on the "Printer" after performing the above step. Go to the "Printer Menu" and select "Cancel All Documents". There could have been a stuck print job that would cause the printer to go offline. Try once again to set the printer back online and try printing a test page.
Turn on the printer. Make sure the printer is turned on and turn it off, wait a minute and then turn it on again. Check to see if the is jammed. Check all the network connections to make sure none are loose. Repeat the above steps again if necessary.
Restart the computer. If this doesn't work, you will have to reinstall the drivers. Go to "Settings" then "Printers" and select the printer. Right click on the printer and choose "Properties". Under the "General" or "Details Tab" look for the driver button and select it and choose the driver again. You may also have to download the driver from the printer manufacturer website.
Reinstall the printer. Under "Printers" in the "Settings" menu, go back and select the printer, then delete the printer and reinstall the printer through the add printer wizard. Use the latest printer driver from the printer manufacturer's website.
Hope it helps.
Thanks for using fixya.......
Dec 06, 2010 | Epson Stylus NX100 InkJet Printer
I cannot use my printer wireless(officejet 6500), it's saying it is offline but works with USB cord. I have reloaded software several times.
Download HP Print Diagnostic Utility -
from the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&softwareitem=mp-86318-1&lang=en
There should not be any check mark next to pause printing and use printer offline
Open Printers and Faxes folder
Right-click the name of the product, and then click Open .Click Printer .
Check the printer queue menu - look for pause printing and use printer offline items - there should not be any check mark, click to clear them
Nov 03, 2010 | HP Officejet 6500 Wireless All-in-One...
My daughter is at college and called me. Her printer won't print and it says offline in the control panel. Its a brother mfc 255 cw
Your going to laugh when you see how to fix this! At least I did the first time it happened to me.
Open a document that you want to print. Go to the top of the page and find where it says "File". Click on file and follow the drop down list almost to the bottom where it says Work Offline. Click on Work offline and this will put your printer back on line and able to start printing again.
Sep 30, 2010 | Office Equipment & Supplies
Unable to print from computer, nothing happens when i click print, yet printer will print from scanner. it is a h.p.psc1300 all in one.when i go into the printer on computer it says printer offline error...
I'm assuming it's USB and it got unplugged or turned off recently. Unplug the printer's USB cable for a bit (20 seconds), then plug it back in. Most likely the computer will recognize the new hardware and begin the software install that's needed. When you look at Printer on the computer again, you'll probably see a new one, but it'll show ONLINE. Make this one your default and delete the one that shows OFFLINE
I've had this happen to me several times and the above solution works for me. Good luck.
Jul 27, 2010 | HP Office Equipment & Supplies
Windows says printer offline, but it is not offline. network settings confirmed. windows firewall turned off. scanner works perfectly over network, but printer is "offline"
The printer offline error mostly troubles windows 7/8/10 users, The printers loses connectivity even when it is connected and operating. The status message displays offline on the computer, and the printer does not print. An Offline status indicates that the computer has failed to communicate with the printer. In some network conditions, the printer might get offline unexpectedly.
Before going to the solution for this you must know when and why printer offline error takes place:
The error may appear when Windows 8 diagnoses that the printer is unavailable, but unfortunately, most times it fails to tell whether the printer is really offline or if it has connectivity problems or printing errors. Reasons why your printer appears to be offline, include problems with hardware, such as disconnected cables or malfunctioning equipment, and problems with software, such as corrupted or incompatible driver files.
These might occur when:
1. The connection between the computer and the printer is slow/unresponsive.
2. The printer has encountered an internal error
3. There are multiple unfinished print jobs in the queue.
There are some simple steps you can follow before going to any complicated way:
Your printer offline can be a problem with the driver software. This is a small piece of code that Windows and the printers use to "talk" to each other. If the driver software is outdated, corrupted or incompatible with the version of Windows that you have installed, you may need to update it.
Restart the printer and the computer or unplug its USB cable.
Do check that the printer's power cable is plugged into an electrical outlet. If the printer is connected to a power strip, make sure the strip itself is connected to the electricity supply and is turned on.
In case you are using a network printer both wired or wireless, You restart the router as it may cause due to network failure.
Different manufacturers come with their own diagnostics software which can inform the user about the problems coming up (Ex : HP's Print and Scan Doctor), Use it as it will be really useful.
PRINTER OFFLINE ERROR Solution 1 :
Type in Services in your windows searches and hit the enter key. Click on Services option from the set of search results as shown below.
A new window for Services opens up. Scroll down and find the entry named Print Spooler.
Now right-click on Print Spooler entry and then on Properties option.
Set Startup type as Automatic from the drop-down menu.
As next, hit the Start button and wait till windows start the Print Spooler. Once done, hit Apply button.
Now if you look at the status of the Print Spooler, you can see that it is Started.
Solution 2 :
If the above method doesn't work for you, you can always try our second method. For that, type in Devices to the windows search and choose Devices and Printers from the search results.
Now find the printer that is offline and right click on it. Click on the option See what's printing from the context menu that appears.
A new window opens. Now click on the Printer tab and uncheck the option that says Use Printer Offline.
Aug 04, 2009 | Canon PIXMA MX850 Multifunction Printer
My hp f340 says offline in the print query and
go to start menu select printers and faxes or go to control panel, select printers and faxes, open and select your printer right click and scroll down to use printer offline and click it will work, dont forget to rank me when it works thanks
Jul 17, 2009 | Office Equipment & Supplies
Printer offline? won't print
please go to start menu, select printers and faxes or control panel to select printers and faxes open it, right click on your printer and scroll down to select use printer offline. then u are safe to print start ur printing. dont forget to rate me when it works am sure it will work. thanks
Jul 17, 2009 | Brother HL-2040 Laser Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
I have a HP Officejet 6300 and it is showing as Offline
go to control panel, then printers and faxes, then right click on it and click "use printer online"
hope this helps!
Jan 25, 2009 | HP DeskJet F380 All-In-One Printer
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
88 people viewed this question
old marine
old marine
