Question about Sony FV120 Microphone
Bought a new microphone. Sony F-v120. Plugged it into the mic in 3.5 mm port. Realtek audio manager pops up. I click ok. Then when i go to windows recorder, and click record, i am unable to record anything from the mic. but when i speak in the inbuilt mic of the laptop, it works. it records. but not from the mic. please suggest.
  • 14 Answers
SOURCE: Problem recording when connected to computer
In the volume control panel look for mic boost and tick the box to boost the microphone volume. It's under options properties/Advanced controls etc.
Posted on Apr 13, 2007
SOURCE: Sony IC Recorder ICD B600
To transfer recordings from the Sony ICD-B600 to Windows first buy a Radio Shack #42-2497 cable. Connect the cable from the recorder headphone jack to the computer microphone jack. In Windows XP follow the path: start, All Programs, Accessories, Entertainment, Sound Recorder. This small window will allow you to record 60 seconds of sound to a file. Get Article #82215 from the Microsoft web site. It will tell you how to make extended recordings. I was able to record 45 minutes continuously. The recorder is turned on by moving the 'HOLD' switch down. The recorder is turned off by moving the 'HOLD' switch up and waiting 2.5 seconds. Have fun.
Posted on Oct 27, 2008
  • 38 Answers
SOURCE: acid 7.0 music recorder
It sounds like the software is having trouble locating a recording device. If you go in to the settings for the application, you should be able to select/see the audio input devices. Does the device you are trying to record to show up and is it selected as the active recording device?
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: recording conversations which mic to buy?
How many speakers?  In a room?  Outdoors?  What kind of recorder do you use?  What is your budget?  Hi Fi or just need to be able to recognize what is being said?
Depending on your setup you might try:
Solution one: lavalier mics like an Audiotechnica ATR35 on each speaker's lapel.
Solution two: a boundary microphone on the table, like Shure mx395.
Solution three: cardioid pattern mics pointed at each speaker (could also use a shotgun).
Solution four: one figure eight pattern mic put between two speakers facing each other (make sure the axis of the mic points at the two speakers).
Solution five: you could scrap your recorder altogether and get a Zoom H2, put all four channels on and don't thump the table.
Posted on May 17, 2009
SOURCE: sony acid pro 6.0, microphone level when recording is way high
are u using the volume control or what mixer--u might want 2 try out the volume control--set it up recording
Posted on Jul 16, 2009
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
I want to attatch my mic to my motherboard
desktop or laptop computer ?
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
hope this helps
Sep 19, 2012 | Biostar P4M900M7FE Motherboard - VIA...
Microphone Not Working!
If this is a microphone that connects to the 3.5 mm microphone jack, check that your microphone is connected to the Mic port (pink on the rear of a desktop). Make sure that the plug is fully seated. If you are using a front microphone jack on a desktop, try using the rear port (or vice versa). Next, if you have Windows, check that the audio input is set to Microphone, instead of Line In. (For Windows 7, this would be Start > Control Panel > Hardware and Sound > Manage Audio Devices (under Sound) and the recording tab.) Microphone should be your default device.
Next try uninstalling the audio driver and letting Windows reinstall the driver. Use the Device Manager (under Devices and Printers in the Hardware and Sound Control Panel). Expand the section labeled Sound, video and game controllers. Then right click on the Audio driver. Click on Uninstall then reboot the computer after the driver is removed. The correct driver should be reinstalled. (I believe that you do not have a separate driver for the microphone under Windows but you should make certain of that.) Check for driver updates as well. The Windows Update may list these as Optional updates.
If you have a USB microphone, try a different port. Also check for drivers from the manufacturer.
If you have an Apple or Unix OS, check for similar issues with the connection or drivers.
I hope this helps.
(who had a similar problem with Audacity recording on the line in port last month; I fixed the problem by uninstalling the audio driver and then reinstalling it. Then changing the Recording Source to Line In finished the fix. The driver got changed by a computer tune-up utility (registry cleaner).)
Apr 13, 2012 | Labtec Audio Players & Recorders
Audio driver is working properly but mic is not working.....using lenovo g430 3000
If the audio driver is working properly but the microphone isn't, ensure that: 1(a). The microphone is not muted.On Windows XP, go to start, run and type sndvol32 and press enter button to launch the Windows Sound Volume Management Panel. Under the Microphone volume control, uncheck "mute" box.This should make your microphone functional again. (b). The wrong microphone may be selected, esp. if your sound-card has an external port for microphones.To rectify the problem, use 1(a) as illustrated above, go to File>Advanced Controls and select Input Devices.Under the Microphone advanced settings, you'll see MIC1 Select and MIC2 Select. Switch the selection as appropriate until it works. 2. If the audio driver has it's own Sound management Panel, e.g that of Realtek, open it's sound control panel and disable all microphone effects that may be enabled. 3. Ensure that sound acceleration is maximum. Open the DirectX Diagnostics Engine by going to Start>Run> and type dxdiag and press enter button.When the window opens, click the Sound tab and slide the Sound acceleration bar to maximum.
I hope my solutions work.Have a good day.
Feb 11, 2011 | Lenovo IdeaPad Y430-3231U Notebook
SEGMATEL MIC NOT WORKING
1. Click Start
2. When the menu opens, highlight either All Programs or Programs.
3. Click the Dell Webcam folder, then click the Dell Webcam Manager icon to open it.
4. In the Dell Webcam Manager, click the Dell Webcam Center.
5. In the lower right-hand corner of the Dell Webcam Center window, click the drop-down arrow next to Audio Source and click Digital Mic (Realtek High Definition Audio) to enable the microphone.
Alternatively you can try downloading the updated audio driver
http://tinyurl.com/2a3czup
Thanks for using fixya
proton
Jun 09, 2010 | Dell Dimension E520 PC Desktop
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
Hello, i recently bought a new motherboard a Gigabyte GA-8I915P for no reason the mic doesn't work, I've already installed the latest audio drivers for this motherboard, the speakers work fine but why...
Maybe it's not recognized. Unplug every audio device, open Realtek HD Audio Manager and start plugging them back one at a time, the manager should automatically detect that something was plugged in a specific port. Just tell it what you have plugged.
Dec 08, 2009 | Gigabyte GA-8I915P Duo Pro Motherboard
My computer isn't detecting my new microphone?
Check if its plugged in the MIC port or the Headphone port.
Jul 06, 2009 | JVC MV-J3BK Microphone
Camera works but microphone doesn't My wife has a QuickCam Pro 9000 Web Cam - Camera works - The speakers are in the screan and are realtek the computer seems also to be looking for realtek microphone and...
That KachiWachi guy is a **** indeed...
My fix for Vista 64 bit, yellow exclamation mark at Logitech Mic (Pro 9000) in Device Manager:
Right click Logitech Mic (Pro 9000), properties, driver, update driver
Browse my computer for driver software, location should be C:\Windows\System32\drivers, also make sure the Include subfolders box is checked
Click on Let me pick from a list of device drivers on my computer
Make sure there is a checkmark at Show compatible hardware
Select the USB Audio Device instead of the Logitech Mic (Pro 9000) and click next
Now your microphone works by using the generic Windows driver instead of the Logitech ****!
Sep 18, 2008 | Logitech QuickCam Pro 9000 Web Cam
Realtek audio device with sound effect menager
First thing is first, there should be 3 audio jack inputs. Line in, Line out and Mic. Make sure you are plugged into the Mic input.
Next if you are running windows XP check to make sure the Microphone volume is not muted and turned up. Do this by going to control panel --> Sound and Audio Devices --> volume tab --> Advanced button. The Microphone volume should be there if not select file --> properties and make sure microphone is checked. It should then appear on the volume controls.
This should take care of it if not what program are you using the mic with?
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Sony FV120 Microphone Logo
48 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
