Question about Dryers
Duet dryer Just bought the Duet sport dryer and got to use it once. Everything was fine. Went to use it for the second time and it made a humming noise but would not start. I canceled and reset it, pressed start and the sensing light came on but the dryer does not spin. Light changed to wet, but still no spinning. Checked breakers/fuses and reset them. Tried to start again but then a burning smell came from the back where cord connects to dryer. Unplugged it overnight and smell still remains. Any advice?
  • 1,028 Answers
Be sure wires on back at ac connection are tight loose connections generate heat and will cause wires to burn also be sure they connected properly this problem usually falls under installation problems not dryer problem
Posted on May 29, 2008
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My whirlpool duet sport dryer control panel will turn on but nothing happens after that. thecontrols change and everything but no drum rotation, no heat. and every once in a while I get the f-01 error...
you have a blown fuse if you remove the front lower cover you will see a white long fuse about 2 inch long it is bad after you put the new one on it will work but you need to keep the front off and turn on the dryer and look at the heater and see if it is lighting up red all over if not the heater needs to be replace it is shorted out and that is what made the fuse blow
Nov 02, 2012 | Whirlpool WED9371YW Duet Electric Dryer
Switch the 3 prong cord to a 4 prong on my whirlpool duet sport, 9 cycle
Hi mybabycamero
Go to the following webpage and you can see how to convert your 3 wire to a 4 wire dryer.
Please take time to rate me
Oct 17, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How do I clear error code F-28 on my Whirlpool Duet Sport electric dryer?
The tech sheet is located under the kick /service panel in a jacket. Suggetions and codes are in it. Duet sport service manual
Sep 30, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
76 people viewed this question
Top Dryers Experts
