Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Where can I get a wiring diagram for the intermatic t1975
Intermatic t1975 manual
Programming:
Depress trippers to turn on load
First tripper turns on timer for 16-20 minutes.
Each additional tripper lengthens time by 15 minutes
So if you want timer ON for 2 hours, you depress 8 successive trippers
Leave tripper up for OFF times
See manual for day-skipper details
Wiring:
T1975 has 120V clock motor
The load voltage is the same 120V
Timer can control 2 separate loads with SPDT
1) NO normally open pole (no electricity flows until timer turns ON)
2) NC normally closed pole (electricity always flows until timer turns ON)
This timer cannot control 240V load
Posted on Oct 07, 2010
Inter attic T1975 has four wire connections. One says common and load line from breaker is connected to it. Another says clock and neutral line from breaker connects to it. Two other connections are for NO...
click the link below it should help u a lot, if u still can't get it right, contact me @ nchronicpain@gmail.com and I will walk you thru it using Skype or something. don't fully understand what u r trying to do. r u using the wires from the sprinkler to turn it or turn it off.
T1975
I am going to try my best to tell what I think u should either way. if u are using the NC to make the sprinklers run when the timer engages and turns power on. you hook the common wire to the clock side along with the wire for the NO to the same terminal.
the other wire hooks to the NO or the NC contact
Feb 14, 2015 | Intermatic Hardware & Accessories
I need installation or wiring diagram for Timer Intermatic T101
Copy following link for 120Volt T101 timer wiring options:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 29, 2011 | Home
I have disconnected the internal wires from my Automatic Sprinkler Timer model R8806P 101C . and don't know where they are supposed to go. Is there a diagram of that? Specifically, where does the...
Thank you for including model number of product.
R8806P101C is 240Volt timer with 4 wiring terminals.
You removed factory wiring and want to reattach.
The on-off-auto switch does not have separate wiring diagram.
Intermatic offers tech support phone: 815-675-7000
Add a comment and say what you discover.
Open following links for resources:
http://www.intermatic.com/customer%20service.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Aug 19, 2011 | Intermatic R8806P101C -...
The relay on my Paragon 1015-00RS timer has gone bad,, where can a purchase another one
You won't be able to find parts for that timer unless e-bay is selling used timer.
Patriot supply sells new timer, Aug 2011:
http://www.patriot-supply.com/products/manufacturer_detail.cfm?manu_id=191
Paragon is no longer making timers and parts except defrost timers.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic crossover timer is 120Volt T1975, which sells for less and has replaceable 156T1978A trippers and WG733 clock motor. Relay is not replaceable part.
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour/t1900%20t1970%20series.aspx
Aug 15, 2011 | Paragon 1015-00RS Indoor Multi Operation...
My model 1015-00RS timer comes on when it's set to be off at certain times, I push big dial down and it goes off, but then the next day it does the same thing, is there ajustment for fine tuning the...
I might not understand the problem correctly.
Open following link to identify timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
From your post, the large dial on your timer can be pushed up and down?
Or are the trippers popping up?
The dial is supposed to rotate clockwise during regular operation, and can be manually rotated either direction to set current time, but dial should not move in and out or up and down.
If the trippers are worn, then they are built in. The problem is that Paragon is no longer making parts and does not support 1015 timers.
It's possible the trippers might be getting pushed up if the on-off mechanism needs lubrication.
May 2011, Patriot stills sells the 1015-00RS for $187
Intermatic 120Volt-480 Volt crossover product is T1975 (advantage is replaceable trippers, motor and switch)
Grainger sells T1975 for $126
http://www.grainger.com/Grainger/INTERMATIC-Indoor-Multi-Operation-Timer-6X761?cm_mmc=GoogleBase-_-Electrical-_-Timers-_-6X761&ci_src=14110944&ci_sku=6X761
Crossover wiring for 120Volt application:
All wires on Paragon 1 to Intermatic Clock
Paragon 2 to Intermatic Com
Paragon 5 to Intermatic NO
If there are wires on Paragon 6 to Intermatic NC
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Paragon 1015-00RS Indoor Multi Operation...
Ckt diagram
For anyone else who may reading this post, please note that this diagram is for the T104 ONLY.
Here ya go: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Basically, connect the incoming (line) 240 volt wires to terminals 1 and 3 and the outgoing (load) wires to terminals 2 and 4. Of course, connect the (bare or green) equipment ground wires from both cables to the "GR" terminal.
Nov 17, 2009 | Intermatic T104 24h 208-277v Mechanical...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
467 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
