Question about Crosley CAE12ESR Air Conditioner
I have a crosley window ac should it stop for intervals or work all the way
    New Friend:
  • 107 Answers
It will run all day if it does not get to the set point temperature and some units have a switch for the fan to cycle with the compressor or run continously.
Posted on Oct 10, 2010
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
Crosley radio CR248 can not get anything to work display screen shows ON but nothing will work
Type " Crosley CR248 user manual " into search engine and it will show sites to get manual. Some radios have 2 fuses in them. I could be blown. If you attempt to check the fuses... UNPLUG RADIO !!!!!!
Nov 21, 2015 | Crosley Audio Players & Recorders
My crosley dryer (model# CED137SXQ0)made a loud ugly noise and stopped working i tried turning back on but it doesnt come on or make any noise.
check to see if the drive belt is broken. check out this video:
http://www.repairclinic.com/PartDetail/b171p8/Crosley-Dryer-Drive-Belt/341241/529597?modelNumber=CED137SXQ0&ss=a8b171d1287209&mr=1#repairHelpVideoTabs
Aug 04, 2015 | Crosley Dryers
Do I need to replace the battery and buy a converter, or buy a completely new one? Is it completely broken?
Normal the high input voltage should influence the output voltage. The120V AC to 9V DC will be blown, but with a bit of luck, your Crosley cruiser will be ok. Only if the power convertor is poorly made, the high voltage could have gone through the convertor and then it damaged everything in the cruiser. Try a new 9V power supply and see what it does.
Jan 19, 2015 | Crosley Audio Players & Recorders
Problem with ac window unit panel and remote will not work,pushed all bottons to work and just wont.Could it be the mother load panel?
Sounds like a control computer board problem. Some times unplugging and leaving it for about 30 seconds and plugging it back in can recover from the fault.
Jun 29, 2014 | Crosley CAE15ESR 15,000 BTU Window Air...
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
My maytag m6x06f2a-f window AC wont stop beeping
We had the same problem and changed the setting to auto and the unit seems to be working properly now. Not sure if this solves the problem, but for the past 1/2 hour the unit has stopped jumping between 00 and the temp we set.
Jun 07, 2008 | Maytag M6X06F2A Air Conditioner
Crosley 4 in 1 CR-66
The solution is to replace the AC Power transformer. I have the same problem with my Crosley 4in1 machine. I trouble shooted it and got it to start working when I replaced the AC Power Transformer. The problem still is that It needs to be replaced with the correct 'Power Rated' Transformer.
May 25, 2008 | Crosley 4-in-1 Entertainer CD Shelf System
Crosley Dryer Won't Stop When Door Open
Yes, however befor replacing just check it is not jammed on be abiuld up of fluff around microswitch Regards Advisor
Aug 29, 2007 | Crosley CDG6000 Gas Dryer
Crosley CAE12ESR Air Conditioner Logo
100 people viewed this question
Top Crosley Heating & Cooling Experts
ray gallant
Kiri Amarakoon
Level 1 Expert
Are you a Crosley Heating and Cooling Expert? Answer questions, earn points and help others
