Question about Briggs & Stratton Starter Briggs Stratton 394943 490420 494990
My Briggs and Stratton starter will not turn over the engine.
kevin000
  • 1847 Answers
SOURCE: Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Posted on Sep 24, 2008
  • 83 Answers
SOURCE: removal of flywheel from briggs and stratton 4 cycle engine 3 hp
Without the $100 flywheel remover that briggs will happily sell you you can do the following.
First you will need another body to help, two if available
2 pry bars or large screwdrivers
A air hammer if you have it or a large hammer if not
Loosen the flywheel nut until it backed off til the nut is just barely one thread or even with the shaft. Now put your pry bars behind the flywheel on opposite sides. Have someone provide constant pressure (don't be too forceful the block is made of aluminum and can be damaged). Now hit the end of the shaft with a hammer or air hammer (the nut is protecting the shaft threads) with medium power. With a few careful hits the flywheel should pop right off.
If you run into trouble or are unsure of something in this proceedure please ask.
Posted on Mar 30, 2009
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
  • 634 Answers
SOURCE: Having problem starting and keeping engine
some have fuel filter some do not , but it sounds like you have contaminated fuel and is is clogging up fuel line or carburetor,look into gas tank with a flash light and see if there are specs floating at bottom of the tank, if there are drain tank of all gas and remove tank and flush it out with brake cleaner, then disconnect both ends of fuel line and spray through tube into white paper towel until u see no dirt/debris. then remove air filter clean foam( soapy water, dry re-oil 10w30 is ok). remove carb from engine spray through main port with carb cleaner not brake cleaner, and use tube and spray through inlet tube while holding throttle wide open reassemble and it should run fine, if not u may need to disassemble carb if not comfortable with this then order new one usually under $100
Posted on Jul 09, 2009
  • 5 Answers
SOURCE: briggs and stratton engine is hard to turn over
Could be overfilled with oil?
Posted on Aug 28, 2009
Not able to find listing for Briggs Stratton 126907 1473
MAYBE this is the right number ? 12S907 1473 B1 by a little suggestion
http://www.partstree.com/parts/briggs-and-stratton/engines-vertical-engine-with-electric-starter/12s907-1473-b1-briggs-stratton-engine-electric-starter/air-cleaner/
Briggs and Stratton 12S907 1473 B1 Briggs Stratton Engine Electric Starter...
Oct 21, 2016 | Briggs Measuring Tools & Sensors
Sarter will not turn engine over
Two things cause this...a bad starter or weak battery...not sufficient Amps will not allow enough power to the starter to spin it fast enough to start the engine....a bad starter simply cannot use the power supplied it to turn the engine properly. Have some one do a load test on the battery..tests the battery simulating starting the engine. If ok it is the starter if not replace the battery..good luck.
Apr 09, 2014 | Briggs & Stratton Starter Briggs Stratton...
Iput to much oil in a briggs and stratton engine on a wood chipper the engine has seized up what can i do
Drain out the oil, take out the spark plug and see if you can get it to turn. Turn by hand or wrench not an electric starter
Aug 28, 2013 | Briggs & Stratton Briggs Stratton...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Starter turns engine too slowly
If the engine has not been taken apart, then the problem should be either too much oil or a weak battery, and lastly a weak starter. If the engine was "rebuilt" then the timing may be off.
Feb 10, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Remove starter motor briggs and stratton lawn tractor
My briggs 16.5 moptor wont turn over. It comes up on compression and stops. I have tried to jump it but the cables get really hot. Is my problem in the starter motor?
May 30, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & Stratton Starter Briggs Stratton 394943 490420 494990 Logo
500 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
