Question about Kidde Nighthawk Combo Gas/co Detector
Green light flashing, showing its on battery power only, i checked wires and there is power
Last green light flashes
1 Flash The batteries need charging. Check the battery connections. If the battery There is a bad connection to the batteries. connections are good, then try charging the batteries. 2 Flashes There is a bad connection on the left motor. Check the left motor connections and wiring harnesses. 3 Flashes The left motor has a short to a battery Contact your authorized Pride Provider. connection. 4 Flashes There is a bad connection on the right Check the right motor connections and wiring motor. harnesses. 5 Flashes The right motor has a short to a battery Contact your authorized Pride Provider. connection. Rippling LEDs The charge inhibit has been activated. Make sure that the battery charger is not connected to the power base. 7 Flashes There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. 8 Flashes There is a control system fault. Check power module and joystick module connections and wiring. 9 Flashes The park brakes have a bad connection. Check the left and right motor connections and wiring. Check to make sure that the power chair is not in freewheel mode. 10 Flashes An excessive voltage has been applied to Check the battery connections. the control system.
or go here and find yours,if you would of given the info we need,i would of diagnosed it for you,but,you didnt Pride Mobility Products Corp Basic Troubleshooting Instructions
Apr 20, 2015 | Health & Beauty
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Samsung Sync Master 914 has no picture. When power supply is only in, green light flashes slowly. When both power and vga are in, green light flashes more quickly. I hear a faint clicking sound coming...
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Dec 03, 2009 | Computers & Internet
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Kidde Nighthawk Combo Gas/co Detector Logo
180 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
