Question about Dishwashers
Kenmore model 16579200 is stuck on wash cycle. starts at 81 minutes goes to 73 minutes and stays there. any ideas?????????
  • tpschultzyob Oct 06, 2010
    On the parts list it does not show a timer switch. It shows electronic control, is that part of the timer? Its the kenmore eleite model
  • 11,896 Answers
Timer is bad and will need to be replaced.
Posted on Oct 07, 2010
    Brigadier General:
  • 3,513 Answers
If your dishwasher isn't draining then you will have to take off all of the shields on the bottom of the unit (on the outside) then you will see the motor. Unplug the dishwasher then put your fingers in the motor and start to turn it to free up the motor, the motor is kind of like a vacuum cleaner belt, so when you hand turn the motor you're allowing the belt to slip back into its grove. then when you're done plug it back in then turn the dishwasher on and it should drain.
Or if your dishwasher fails to complete its cycle, there could be a problem with the timer switch. The timer is what guides the dishwasher thru its various stages. If the dishwasher stays stuck in one cycle- doing one job continuously- or advances thru a few cycles and then stops, suspect a malfunctioning timer. Purchase a replacement timer. Remove the front panel of the washer and find the switch. It is usually right behind the control knob. Snap a few digital photos of the wire assembly to simplify installation of the new switch. Simply remove the old switch and replace it with the new one. Sometimes, a bad heating assembly can cause the washer to not advance past it initial starting point. On dishwashers that preheat the water, there are 2 methods to this. Some use a timer when heating the water, others use a temperature sensor. The ones with with a timer will advance the cycle regardless of water temperature. If there is a problem with the heating element, then the water won't heat up and the washers with temperature sensors won't advance the cycle.
There also could be a problem with the cycle extender or selector switch. Call in a repair person to diagnose the issue thoroughly.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 06, 2010
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
My Kenmore Washing Machine Model 110.82872100 goes through the wash cycle then gets to rinse cycle fills with water makes a clicking noise and stops. Does not drain but cycle knob moves. An electrical...
Your motor is getting overheated in wash cycle. if you turn it off for about 15 minutes and start it back up in rinse cycle will it work ? If yes, then motor is overheated. A sign that the motor is over working its self and time for a new motor.
Dec 15, 2010 | Washing Machines
Kenmore Elite model 42934. Problem washer only
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 26, 2010 | Kenmore 42822 Front Load Washer
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Washing machine will not start
The washer has a stuck button on it which usually means you need a new control panel. Let me know the model # and Ill let you know for sure. Thanks
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwasher won't start
Drhook65,
Welcome,
I'm Huuum
How old is this dishwasher and the complete model number is?
You said, you have a Kenmore Ultra Wash dishwasher, and you have power running to it, but when you shut the door on it...it still won't start a cycle. Does it have a reset button on it? Any ideas on a solution?
Yes, you may try this to reset the system.
Go to the breaker and switch it off for 5 minutes and the on and try it. It usually resets the systems.
Let me know ho it goes. Huuum
Do not forget to leave a rating.
Sep 24, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
121 people viewed this question
Top Dishwashers Experts
