Question about Brother MFC-9440CN Laser Printer
Brother mfc 9440cn laser printer error code 32
Semi-Driver
  • 434 Answers
SOURCE: our Brother MFC 9440CN laser printer memory, keeps
When Fax Storage is set to On, copies of all received faxes are stored in the memory, thus using up a portion of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify that Fax Storage is set to Off by doing the following:
  1. Press the Menu key on the control panel.
  2. Press the Up or Down Arrow key until Fax appears on the LCD. Then, press OK.
  3. Press the Up or Down Arrow key until Remote Fax Opt or Advanced Fax Operation appears and press OK.
  4. Press the Up or Down Arrow key until Fwd/Page/Store or Forward/Store appears and press OK.
  5. Press the Up or Down Arrow key until Off appears and press OK.
  6. If you have faxes stored in the memory, you will receive a message that reads Erase All Fax? 1. Yes 2. No.
    If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Posted on Dec 24, 2009
  • 163 Answers
SOURCE: I have a MFC-9440CN Brother printer. It displays
Don't know what the error means but you could try powering off the printer and re-starting it again, you may lose your print job but the error should have fixed. Hopefully!
Hope this helps!
Posted on Feb 06, 2010
lserni
  • 466 Answers
SOURCE: I have a Brother MFC-9440CN Laser Printer -reinstall tray message
Rule out the software solution: is the document being printed of the same size of the paper in the tray? If not, you'll get a spurious tray error every time you print and then e.g. someone else prints another document with a different format. See Control Panel > Printers > Properties > Tray for this.
Then the hardware/firmware options: there could be either some dust or grit in the tray sensor, so that it doesn't "feel" the tray until it gets nudged, or the chassis (or maybe the tray) got slightly deformed and no longer properly activates the sensor. This is a white dot inside the tray slot on the bottom upper left; try blowing some compressed air on it. A McGyver solution to a warped chassis can be to apply adhesive tape on the facing part, so that it is thickened and improves contact with the sensor. Not really recommended of course, and the tape is bound to come off or wear out, and maybe jam the sensor even worse, sooner or later.
A replacement tray kit may cost anywhere from US$ 150 to US$ 300 depending on source.
Another possibility is that the tray counter has reached end-of-life. Press # 72 and check whether the page count is 288,888; in this case there's a firmware problem and I am not sure of the solution (it's known as the "Brother 288,888 page count problem"). This is unlikely - I don't know that firmware ever got in the 9440. But checking costs little.
I quote the reset procedure for end-of-life reset -- use wisely.
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
Press 3 and 9 at the same time in the ready status on power on.
The “Reset Menu” will appear on the LCD. Choose applicable periodical replacement part with the arrows. Accept with OK. Press 1 to reset the counter, or 2 to quit without saving. STOP to exit menu.
WARNING: using the machine with an end-of-life'd component may damage the machine, not only that component.
Hope some of this helps. Let me know how it goes...
Posted on Mar 24, 2010
  • 39 Answers
SOURCE: Brother MFC-9440CN Laser Printer how do i set
The only real way to make this printer wireless, is to connect its ethernet port to a wireless router and via the router, send jobs to the printer wirelessly. hope this helps. Cost is about $60-$70 for the router.
Posted on Apr 04, 2010
dDex
  • 145 Answers
SOURCE: How do I connect my Brother MFC-9440CN laser
You need to supply IP address to your printer then the the Laptop also needs an IP. Try to ping first the printer IP add if its visible. thanks.
Posted on May 22, 2010
Brother MFC-9440CN Laser Printer knocking noise on startup and printing
Throw that piece of garbage out and get an HP or Samsung. One of these has plagued my office for years and I've spent countless hours plotting its demise. Worse than useless: unreliable.
Mar 25, 2014 | Brother MFC-9440CN Laser Printer
Error code 32
change the waste toner. if that doesn't work might mean printer life is up
Jul 25, 2012 | Brother MFC-9440CN Laser Printer
HOW TO USE AS A COPIER
here is the manufacturers link for all user guides for your Brother MFC-9440CN Laser Printer http://www.brother-usa.com/support/default.aspx?PGID=5&R3ModelID=MFC9440CN thank you and please remember to vote
Nov 29, 2010 | Brother MFC-9440CN Laser Printer
Apr 03, 2010 | Brother MFC-9440CN Laser Printer
I have a MFC-9440CN Brother printer. It displays Print Unable 32. What is the problem?
http://www.youtube.com/watch?v=6Bob34TLrPQ&sns=em This YouTube video shows how to fix this problem with a small piece of tape! Save the 100 bucks.
Feb 06, 2010 | Brother MFC-9440CN Laser Printer
Drum error
You need to replace the drum.
May 27, 2009 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
383 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
