Question about Sharp Office Equipment & Supplies
I need to remove the HDD from a AR-M455N and replace fro return to leasing. I am sure there is reformatting involved when the new one is installed. Can you help with this procedure?
    Scholar:
  • 159 Answers
Be very careful here. If you are replacing this with another leased machine, get the Tech to remove the HDD from the old machine and request that you keep it. Other wise look over his shoulder as he re formats the HDD and get him to show you the empty file directory. BTW there are programs available to hackers to read so called erased files, that's why it's best to request you keep the HDD, they are cheap now anyways.
Posted on Oct 06, 2010
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
Scan processing slow
Try making sure there is no power filter on the network line, and that the network line has a straight shot to the router without going through any other 5 port switches or anything. normally when the scans are slow, and the prints are slow, it's a cabling issue.
when you're ready to replace that old thing request a quote from Skelton!
Copier Quote Houston Lease Rental or Purchase Price Cost On New or Used...
Jun 19, 2014 | Sharp AR-M455N Copier
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
How do I remove the hard drive on a AR-M455N before shipping?
If you have a finisher installed on your machine or any other accessory it needs to be removed. Then on that right side the panel comes off with 2 shouldered screws. Next you have to remove the HDD cover which is located right at the top almost centered on that right side. Its 2 screws and you remove the HDD connectors and then unscrew the the HDD from the frame.
Oct 28, 2011 | Sharp AR-M455N Copier
We have a sharp model AR-M455N with an error code of L4-02. The copier repeatedly jams. We clear the jam get another 20-50 copies and it will jam again. Any help? Thank you
Hi, please do not attempt to do what i will advice if you are not an experienced technician as more harm may be done if you attempt. This is a problem to do with main motor overload or a jammed and dry drive unit.
Solution
  • Open the back cover while the machine is out of mains power.
  • Open the main drive unit carefully and clean the gears with alcohol and all the shafts and bearings. Allow them to dry and check for any worn out and replace.
  • Return every piece where it was carefully and oil them well. Try to rotate the gears with your hand before you screw it to the machine and make sure they are moving freely.
  • Check the main motor for any notable defect and screw it well in its position.
  • Check the rest of driven units like developer unit and make sure it is smoothly running. Check also the fuser unit for the jammed parts and oil if necessary.
  • Test run the machine and make several copies like 100 and if okay, return all covers and proceed.
Good luck.
Nov 17, 2010 | Sharp AR-M455N Copier
Error code U2-22 Model #AR-M455N what's wrong with the copier?
MFPC SDRAM memory check sum error. Remove the back print control board (shiny metal + slides out like a draw) remove and refit memory cards.
Sep 27, 2010 | Sharp AR-M455N Copier
Need to download latest printer drivers for Sharp copier AR-M455N
Copy this link to download the driver needed
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
May 15, 2010 | Sharp AR-M455N Copier
I need a printer driver for Sharp ARM455N
Hi david...
Sharp AR-M455N printer drivers can be found at driverupdate us (xp/vista/7/8/mac).
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Dec 04, 2009 | Sharp AR-M455N Copier
I am looking to purchase a AR-M455N, are there known problems?
Thats a very good copier which is fast and can be networked. Problems are those with other copiers so no need to worry.
Nov 10, 2009 | Sharp AR-M455N Copier
Duplex Set-up fro Sharp AR-M455N
does the machine have a duplex fitted? as it is an option for this machine either called a du3 or du4. It bolts onto the left hand side of the copier. On the lcd touchpanel you should see it sais 2 sided next to the output box, tap it and select 1 to 2 or 2 to 2 depending on your origonals.
Dec 05, 2008 | Sharp AR-M455N Copier
182 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
