Question about GE Refrigerators
GE Refrig MODEL GTS22KPB defroster not running fridge warm/freezer cold
A few days ago the defroster was running all the time. Now it is not running at all. The temp in the freezer was 30 and the fridge 55. There is a slight hum and the the freezer seems to be getting colder, but that could be because it is empty. Both dials are set to 9. Please help, this thing is only a year and a half old and I am on a fixed income.....
  • 1 more comment
  • marymommy May 28, 2008
    Their is no back plate on this fridge. It is completely sealed except for the area at the bottom where the compressor and fan is. ? I cleaned it out and the fan is running and the compressor seems to be running but still not getting cold...
    No sorry, no plate. Completely sealed except the bottom Their are stamped indents, but nothing removable. VL307665 serial no. my e-mail is
    Page 44 looks like mine but on page 42, no mine is sealed. Also sent you an e-mail.
  • 770 Answers
You need part WR55x10552 Main Control board it is embedded in the back wall of the unit with a cover plate about 6"X8" unplug and replace this board ctrls it all
Posted on May 28, 2008
  • Gary Davd
    Gary Davd May 28, 2008
    top back left side of the unit see a plate there?? also post your email i will send you the manual
  • Gary Davd
    Check your email and look at pg.44 it will show you what i am talking about. this is for the model you gave me GTS22 This is the board
Ge tv239461 freezer is cold but refrig is warm
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
This will help.Thanks.Helpmech/.
Oct 27, 2011 | GE Refrigerators
The top half of my side by side refrig is warm but the crisper food is cold and the freezer is working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Jan 13, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Refrigerator and freezer
Is the fan behind the back panel underneath
running (condenser fan) may be dead or clogged
with something if not thats the problem if it is
running take a vac attachment and clean
the dust or blow the dust from underneath
the refrigerator (after turning it off)dont bend
anything,After verifying the condenser fan runs
and cleaning the condenser try it out
If there is no improvement and,
If the system has not been opened before I
would say there is a leak in the system
(low charge) Requires the
attention of a service person
Nov 23, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
