Question about NEC NP400 Projector
My smart board projector shows images upside down. I don't know what I did with the remote to do this. How can I correct this? Thanks
Did you get it fixed,. I did the same thing to mine this morning and no one at school can undo it.
Posted on May 09, 2011
  • sheyni May 10, 2011
    Go to Menu: Set-up: Installation: Orientation: Ceiling Front. Done
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
Why is image upside down? the image appears inverted on the board
You need to set up the image using the menu. Press menu button on the remote then use the arrows to go down the list until you come to "mirror". Now press the enter button on the remote several times to cycle the orientation of the image (on some remotes you may have to use the right arrow button instead of the enter button). The projector will remember this setting next time it is switched on. These options are there for people who use ceiling mountings that hold the projector upside down.
Jul 10, 2009 | Epson EMP-S3L LCD Projector
Lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
May 29, 2009 | Epson PowerLite 62c Multimedia Projector
Upside down image
I fixed it by finding a site that posted a solution without misleading and charging for the info.
Mar 19, 2009 | Hitachi CP-X253 Projector
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Image is upside down
Hi
We have image upside down on our smart board.
Jan 02, 2009 | Toshiba TLP 710 Multimedia Projector
Xd70u upside down image no remote how to control with PC
Try the menu feature, then installation, image reverse until it gets to the correct position. Note, the Image Reverse rotates in quarters. You can also access the Menu feature from the projector. It just happened to me and as I was looking for answers and playing around with it, I fixed it!
Good Luck!
Nov 25, 2008 | Mitsubishi XD70U Multimedia Projector
Picture is upside down on screen
go into the menu using either your remote or the button on the projector itself. At the top are several options i.e. "picture" scr-adj. Click over to the right ONCE to "SCR-ADJ" this stands for source adjust. Then look for something called like PRJ mode (projection mode) This tells the projector which direction to display the image so that incase you want to hang it from the ceiling upside down you can. Click down to that menu option. You will then have to click over to the right in order to see your options. If you are using it hanging on a ceiling you want it to say "ceiling front" if it is merely sitting on a cart or a shelf just put it on "front".
Good luck.
Aug 12, 2008 | Sharp XR-10X Multimedia Projector
Nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Apr 09, 2008 | Office Equipment & Supplies
The picture become upside down
You need to change it to front/ceiling in the menu function of the projector.
Oct 03, 2007 | Epson PowerLite 62c Multimedia Projector
NEC NP400 Projector Logo
1,695 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
