Question about Whirlpool Duet GHW9150P Front Load Washer
F 21 error code - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 06, 2010
2010 Kawasaki VN1700 Classic error code 21
Hi, Simon for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Error code 21
Kawasaki Fault Codes
Kawasaki Vulcan 1700 Nomad Service Manual
OEM Parts for Kawasaki
2010 Kawasaki Vulcan 1700 Classic LT Owner Manual
Oct 21, 2017 | 2010 kawasaki VN1700 Classic Tourer
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
Oct 06, 2014 | Washing Machines
I have a mit WS65411 shutdown error code 21
thats the error code for Xray protection which is usually indicating an issue with one of the CRTs and the safety shutdown kicks in and the 21 error will be stored.
Feb 05, 2013 | Televison & Video
My canon pixma printer is showing error code 2 140 21 while scaanning???
i got this error while trying to scan. my ink cartridges were out of the printer (i was going to get them refilled). i stuck the cartridges back in and the scanner worked again.
Jan 20, 2012 | Office Equipment & Supplies
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Error code 21
There are 3 step to repair 21 error
If you got 21 error then there is a 94% chance that your computer has registry problems. To repair 21 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 21 error.
Jun 09, 2009 | Yahoo Mail
I have Hp Plotter 500 and i am getting error code 21:10.
your printer error message 21:10 is about service station or carriage problem, the fix steps follow here:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html#P16_845
hope help you fix it. take a rating let me know how much helped you thanks!
May 21, 2009 | HP DesignJet 500ps InkJet Printer
What is a code 21 on a WS65809 mean? My red crt is not working.
X-Ray Protect circuit error code 21, make sure your counting it right because code 12 is no error
May 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Error code F-21
Hi there, I think the first thing you need to do is check the pump and make sur ethe impeller inside the pump is actuall turning and in good shape. Something may have passed through and in the course, sheared off the impeller fins. Chekc closely... Thanks
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
320 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
