Question about Samsung Washing Machines
Our front loading washing machine washer got damaged (pen drive got stuck). We complained in July.The machine continued to wash well for another one month. The samsung Customer care staff came on 24/8/10 and said that it is better to get the drum also changed. They came and took the machine on 2.9.10. Today i.e. on 6.10.10, they say that no parts are available and as the machine is 7 yeas old, it is having zero value and they are going to return it. How can I get justice? How can I get it repaired? All the items I use in the house and my work place are Samsung. I always used to recommend samsung to every one. And if this is the kind of support I get from Samsung, what should I do? It is an SWF-P10 model. Kindly help. Regards... Silvi Jaganath... Ramamurthynagar, Bangalore
  • Samsung Master
  • 4,340 Answers
Well, if parts are not available, there is little that you can do with that machine. You can try non Samsung, like independent appliance stores, they have parts, often.
Posted on Oct 06, 2010
Wfw9150ww00
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My front load washer goes into pause two min after machine is started i have to press start for cycle to continue and sometimes it does it a second time press start again it will then finish cycle
you should check button start / pause the washing machine, if it is damaged you must replace it with a new one, the damage caused by the push button which is not connected properly.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
My front loading washing machine, GHW9100LW2, Serial# CSR2103781 (purchased in July 2004),has started to stop in mid cycle and throw an F 11 signal, and the door will not open. If I cancel the cycle,...
You need to check and replace water fill valve (blue) located on the back where hot water and cold water hoses connected to the washer. It may get stuck due to corrosion in pipe. Part may cost around 35 to 45 dollars. Next item needs to check is Flowmeter (white) connect after water fill valve. When get dirty water cannot get into washer. The water pressure valve is the last thing to check and replace if the problem is not fixed.
Good luck.
Dec 02, 2009 | Whirlpool GHW9100L Front Load Washer
Washing machine wont go out of first cycle
Hi, you will need to replace the control unit in this washer asap. it has failed due to circuit damage locate din the logic sector.
May 30, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
When we turn on our front load washing machine it trys to drain. it does not start filling with water it acts like it might be stuck on the drain cycle
Seems it detects water from previous run. Is common phenomenon on bad drain hookups or faulty vacuumswitch. Rarely, the timer is damaged.
Apr 09, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing machine
I think that you have a faulty motor. Are there any visible cracks in the stator? The rotor position sensor could also be faulty.
Apr 10, 2007 | Maytag MAH6500 Neptune Front Loading...
Black marks on clothes
My wife complained that we were having similar problems recently. After investigation I located the remains of a pen entering the filter and removed this and did a few empty boil washes to remove any remains of ink and this worked for us. Check the filter and hose between the drum and filter.
Mar 03, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
149 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
