Question about Dometic Rooftop RV Air Conditioner
I turned on my roof top Duo Therm a/c unit on my camper trailer. I had a tarp on top and I forgot to remove this before statting unit. It cooled for a few minutes then I heard a pop and the a/c stopped blowing cold. The fan still blows? Is there a rest button or a breaker, where are thsese located.Thanks
  • lupe_cruz Oct 06, 2010
    where are these located on the a/c unit. capacitor and or breaker
  • 2,272 Answers
I will explain:- When the Ac fan is working properly But unit still does not blow cold air , then the problem can be any of the 3 things given below :--
1)low freon in compresser 2)capacitor pops and blows out 3)compresser itself goes faulty
Possibility number 1 does not apply for your problem as you said the unit was working properly till now and suddenly stopped blowing cold air. So in your case it can be any of other 2 issues mentioned above.
The first thing you need to check is the capacitor in the outside unit. Look at the top of it and see if its bubbled up(bulged up) any. If so, replace it and that may solve it. If it looks normal, (no bulged top) you need to purchase a hard start kit. They are 2 wires and hook up on the run capacitor and it gives the compressor a jump start. If that doesnt work, you need to replace the compressor.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 06, 2010
  • 2,973 Answers
It seems that the pop sound was bursting a capacitor or some such thing in the circuit. No resetting will help. What will help is replacing this blown item. It happened to due to excessive heat trapped inside the tarp.
  • Rinoo Kumari Oct 06, 2010
    On the electrical motor. A small cylindrical object.
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Nov 04, 2009 | Heating & Cooling
Dometic duo therm thermostat
Try properly re-soldering the switch connections to the circuit board. Mine had separated and it did the trick for me!
Sep 16, 2009 | Heating & Cooling
A duo therm thermostat (p/n 3105058) was removed because it would not operate the air conditioner/heater in a firan fireside camper. it was knocked loose from the wall damaging it.the thermostat is for use...
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Fan will not come on
maybe the capacitor for fan was already busted try to check that.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
97 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
