Question about Sony Cybershot DSC-T200 Digital Camera
Sony Camera reset to default setting?
Hi, i have the same problem with my camera the pictures are bad compared to all my friends cameras its too bright and i've tried messing with the settings but i think i've made it worse, so did you ever learn how to reset it to its default setting ?
please let me know
  • surf_girl141 Apr 30, 2009
    got the same problem in a way, but mine is in japanese, could you give me step by step instructions on where to press?
    Problem Solver:
  • 5 Answers
I do have a DSCT100 which has the same menu for this model.
You could go to the HOME menu, look for the Settings icon that looks like a briefcase. Inside the settings go to Main Settings 1 and look for Initialize.
You could also reset it by removing battery for a few minutes.
Hope this helps...ü
Posted on Jun 18, 2008
Hi. i have sony w120. its not new, i bought it cca 3 years ago. I didnt use is for a quite a while (but my family did), so few days ago, i realized when i take pictures, pictures are somehow blurry,...
Please go to Setup menu and select Initialize option to reset camera to default settings that might solve blurry picture problem, if that does not help then its technician job to adjust focus of camera.
Thanks.
Aug 02, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Hi . when i turn my camera the display is on access word. Only i need how can i reset my camera and its model is{SONY cyber-shot DSC-W55. okay solve my problem as fast as you can.
To resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Initialize can only be done if you're able to access the menu of the Camera. To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
May 09, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
My DSC-T10 Sony Digital Camera fell down and now the new pictures taken are coming Blurry (hazy). My old pictures in the memory stick shows perfect. Please advise what could have happened.
Based on the information you've provided, it seems that the Lens Mechanism of the Camera is damaged when it fell down. The Lens of the Camera is not focusing properly while capturing the images. As the issue is with the lens mechanism, the previously captured images are displaying normally. I suggest that you try resetting the Camera and check if the issue can be resolved.
Turn on the camera.
Thanks for contacting FixYa.
Apr 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
How to disable the vibrate function in my sony cyber shot DSC-T70 and where i can find it
There is no option in the DSC-T70 Camera to enable or disable the vibrate option. The vibration in the Camera is a malfunction. The Camera may experience an issue where an abnormal internal vibration and an inability to properly focus and take pictures. Try the following troubleshooting steps and check if the issue can be resolved.
Follow the steps below to perform a manual power reset.
Turn off the Camera.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
If the issue persists after the power reset, then reset the Camera back to factory default.
To reset the Camera back to factory default, select the INITIALIZE option under Main Settings 1 Menu of the Camera to OK. (HOME-->SETTINGS-->MAIN SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK).
If the issue occurs again, then service may be required.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
How to reset to factory specs
There are two types of Reset options for the DSC-H9 Sony Camera, one is power reset and the other is Initialize. Follow the steps below to power reset the Camera:
Remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Initialize:
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
HOME-->SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK
Aug 07, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
New battery and the yellow charge lite come on for about 24 hours then flaches takes 20 or 30 pictures and dead battery
Well first of all you can try to reset your camera to default setting (Most of the time it works), please follow the below link to know how to reset your camera -
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C265373&fes=true
Good Luck!!
Thanks for using FixYa!!
Jul 27, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony DSC T100 will not focus, nor take the photo.
if the hand icon is displayed while taking a picture, then according the camera the device is under vibration. this message is due to the fact that the lens array is under a serious problem and probably you should have dropped it.
it costs about 60$ to repair it under sony.
Jun 22, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
Camera reset for w90 and w200 sony
If camera is DSC-W90 and DSC-W200, go to camera menu and select Initialize -> OK
That will Reset camera to factory default settings.
Feb 23, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Want take a picture
Try to reset the camera as in my other posts here in this thread on Sony problems.
The reset button is under the battery door. Push the button, close the door, start the camera and reset all the settings to the way you want, including the date and time.
Jun 01, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
850 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
