Question about Honda Mmd 5000 Watt Electric Start Generator W/ Engine Ngk 6000HE
My honda 5000 runs great for a couple of hours then it slowly starts to die down.when i stop it and wait 1 minuite it runs great again then lasts a couple of hours then starts to die again
  • Honda Master
  • 7,733 Answers
Gas or Spark Plug!
Posted on Oct 06, 2010
1995 honda odyssey starts and then dies
Isince it cranks, means you have power, elctric system is ok! I guess.. this could be a result of gas delivery problem... either a pump or gas circuit controller.... OR a small propable reason if you have an immobilizer (electronic chip on key!)... but there should be the securit key highlithed on dashboard...
Sep 01, 2012 | 1995 Honda Odyssey
My f 250 starts idles down then stops wait a couple of minuites and it will start and do the same thing. doing this about 5-10 times then it will run great. the funny thing is it only does it 50 degrees or...
This is just a WAG, but it sounds like your choke has sticking in the totally closed position and then pops open when it warms up.
You might start out with just carb cleaner, to see if something has gunked up the butterfly.
Jun 25, 2011 | 1988 Ford F 250
1981 Honda CT110 trail. Runs perfect for about 5 miles then dies. Starts a couple times each time slowly idling down until it dies then it will not start again for until it sits for an hour or so. I...
It sounds like you still have dirt floating around. What did you coat the tank with? I used POR-15 with great results. Install a gas filter that you can see through and see if you are still getting dirt from the tank. Check the new carb for dirt. It sounds like something is somewhat plugged which allows gas to slowly fill your carb after it sits. But this clog is what causes your bike to stop after 5 miles. Does your tank have a shutoff valve? Run a line from the valve to a jar and see how well the gas flows. The shutoff valves usually have a screen....check it for dirt.
Nov 26, 2010 | 1982 Honda VT 250 F
I have a 2001 GMC 2500HD. While driving down the
It sounds like your alternator might be starting to go bad and the Battery Light is coming on because it is not charging the battery correctly. Have your Alternator checked with a volt meter, it should be reading 13 to 14 volts if working correctly. If not, replace your alternator.
Jun 15, 2010 | 2001 GMC Sierra 2500HD
Car stalling out and bot starting after being driven for awhile.
mcdevito75 Here, It"s possible the ignition Module is going bad, no way to test and if so, one day the car will not start at all.----------It can also be a vapor loc, wher the fuel is evaporating before it reaches the cylinders. Best Bet, have your local shop check both these items.
Jan 01, 2010 | 2000 Dodge Stratus
94 Honda Accord will run, but then slowly dies.
have your catalitic converter checked
Sep 21, 2009 | 1994 Honda Accord
I have a 2004 Mazda Tribute
I recently solved the very same problem on my tribute. I really needed a tune up, Plugs, fuel filter, pcv valve, cleaned throttle body, and mass air flow sensor.My problem went away, and engine runs great and idles perfect.. If you havent had a tune up recently maybe this will help you.
Jun 20, 2009 | 2002 Mazda Tribute
Dies after running
When it won't start does it have spark? (Ignition module)
Apr 08, 2009 | 1989 Pontiac Firebird
Honda Mmd 5000 Watt Electric Start Generator W/  Engine Ngk 6000HE Logo
307 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
