Question about SanDisk Sansa e250 MP3 Player
Computer doesn't recognize MP3 player -
I recently got a Sansa e280 mp3 player as a gift. I've tried to download songs to it by copying songs to my laptop, using Windows Media Player 11. I have made a sync file, but when I connect my mp3 player to my computer, using the cable that came with it nothing happens. The "Start Sync" button does not light, and as player is not recognized. I've hit the "refresh device" button, and the "device refreshed completion" flashes, but I still can't download my playlist to the player. device not recognized
  • tjfrench May 30, 2008
    I connnect my Sansa e250 to my computer and nothing happens while on the player it says im connected. I check my computer to see if its removable devices and it doesnt show up. All my music is still available on the player but i cant add because it wont read the player on my computer. HELP
  • rula ric May 30, 2008
    my computer wont reconize my device. e250r
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
Apr 01, 2009 | SanDisk Sansa Clip MP3 Player
Try to reboot your PC. Leave mp3 player off when start Sync (if button lights up this time).
Jan 20, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jan 17, 2009 | Sony Walkman NWZ-S616F MP3 Player
Don't transfer playlists - only transfer individual songs
Sep 15, 2008 | SanDisk Sansa Clip MP3 Player
I think I have a solution. First you turn on the MP3 Player and then go to the menu. Go down to settings. Then, go to USB. Go down to "MSC" and hit the middle button. It should take you back to the settings menu. That means you successfully changed that setting. Now plug the MP3 Player back into the computer and open up "My Computer." It should show up. I hope this helps!
Jul 24, 2008 | SanDisk Sansa m240 MP3 Player
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
Jul 08, 2008 | SanDisk Sansa Clip MP3 Player
Make sure you are using a data transfer cable, and not just a "Charge Only Cable"... There is a difference, and they may look similar and both connect via USB so it can be tricky.
Apr 06, 2008 | SanDisk Sansa Clip MP3 Player
go on sandisk and do the updates
and changes the format of the hard drive
Mar 25, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
