Question about Hella Keyed Battery Master Switch
How do i fit a master battery switch to adefender 90 diesel?
    Guru:
  • 509 Answers
Just connect it inline on the positive battery terminal.
Posted on Dec 28, 2010
2004 vectra c diesel clutch pedal to floor. Garage changed csc,master cylinder, return spring but pedal still drops to floor. Not loosing any fluid been bled numerous times.Any ideas??
Crack off the slave cylinder bleed nipple. If you get pressure when pumping the pedal, replace the clutch. If not, remove the air lock in the system or fit a new master cylinder.
Jan 25, 2017 | Cars & Trucks
Vf7chrhy339121504
if diesel the engine model should be 2.0 HDI (90/110 HP)
Jul 04, 2014 | 2001 Citroen Xsara
2002 jeep grand cherokee overland , battery power leekage , can i fit a master switch to prevent battery power lost .
There's a very interesting page about battery isolators here: Battery Isolators A lot of the info is about using two batteries, but I think any of these could be used for one battery instead.
Jun 18, 2014 | Jeep 2002 Grand Cherokee Overland
2004 F250 diesel wiring diagram... I want to install a simple kill switch for the starter, injection, something so it will not run.
You can get battery isolation swtches, you could fit one of those between the battery and the starter.
Oct 23, 2011 | 2004 Ford F250
Expert van 2lhdi 2005 very poor starting in cold weather had glow plugs and relay fitted still no better. i only do 3000 a year and mainly short jouneys less the 5 miles. new battery last year. it does...
Firstly fit a manual overide to the heater plugs .relay -push button type switch -wire -connectors ,run a wire direct from battery to relay ,other side to heater plug relay output so it feeds all the heaters ,push button inside cab with a 12v feed from ignition switch running to relay then other side of relay to earth ,leave vehicle on charge often on trickle charge where possible ,also on a full tank of diesel put in a litre of petrol to stop diesel waxing up ,nice old rug or blanket over engine and it will first time every time ,only use the petrol when weather below minus 5c though ,great vehicles these peugeots but i do like my ford transit
Dec 19, 2010 | Peugeot 604 Cars & Trucks
I need a master window switch for a four door Grand Prix SE driver side but can't find one. What year switch can I use
Have you tried a salvage yard? I was a customer service rep. at a very good salvage yard. If they don't have one they should be able to tell you what years will fit. You could try your local yard, and hopefully find one. Ask about a warranty. It may only be 60 or 90 days, but its better than nothing.
Sep 05, 2010 | 1994 Pontiac Grand Prix
I HAVE AN 02 REG RENAULT MASTER DCI 90 WITH 2 INJECTORS THAT I CAN NOT GET OUT. I HAVE TRIED FILLING THE HOUSING WITH WD 40 AND BRAKE FLUID. I HAVE TRIED A SLIDE HAMMER BUT TO NO AVAIL> HAS ANYONE...
WD40 is for rubbing on arthritic joints ,leave for a while ,say a day at least with diesel ,no fancy spray or special antiseize just diesel and they will come loose after a day or two ,also turn slightly with a monkey wrench
Aug 09, 2010 | Renault Sportwagon Cars & Trucks
Toyota Prado Diesel. Electric windows do not operate
Hello! Turn the ignition switch on...Hold the master power window auto up switch for five seconds...Send a comment with results...
Guru........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 11, 2010 | 2004 Toyota Land Cruiser
Diesel pump on a renault master van
EASY ENOUGH JOB JUST MAKE NOTE OF TMING MARKS
Oct 15, 2008 | 2000 Renault 181
Hella Keyed Battery Master Switch Logo
47 people viewed this question
Top Hella Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Hella Electrical Supply Expert? Answer questions, earn points and help others
