Question about Magic Chef Refrigerators
I have an upright refer only unit that I use in my garage. The door does not always close as it should. Is there an adjustment I could make on it so the door closes easier and stays closed? It appears to be sagging away from the hinge as well. I wonder if there is a new angled nylon washer that goes under the door and on top of the bottom hinge to facilitate the closing of the door.
    Sergeant:
    Champion:
  • 351 Answers
I would put some washer on the bottom hing to bring door up
Posted on Oct 08, 2010
The chamberlane liftmaster professional 1/2 hp garage door where I rent, had the door only replaced. Are there certain doors only that will work with this unit? It hasn't worked right since. 1
You need to adjust your force settings and reset your limits to match your new door. this very easy to do, pull up program instructions on your computer. Or contact the owner or property manager to see if they will send a garage door tech out to do this. should only be the cost of a service call 50 - 65 dollars.
Apr 04, 2015 | Building Materials
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 139.53673SRT1 garage door opener seems to hit that screw near the light ending at the up position pretty hard. Is ther a way to adjust that? maybe it always has, but noticed it more lately?
Close the door and while it is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover.
Aug 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
Gagarge door does not reversw to open it always tries to close
Try adjusting the down limit. It is a control on the side of the motor unit. Turn it in the opposite direction of the arrow printed on the cover until the door stops. Then tweak it until it is correct.
Jan 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open and close properly
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Jan 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener intermittently not closing
A couple things to check and do. If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary.
If the main light isn't flashing it may just be a simple adjustment. Locate the 'down force' adjustment on the rear of the motor unit near where all those white wires go. Increase this about 1/4 turn and try.
For the light you should unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close by remote in cold weather
There are ususally two adjustments on garage door openers...
One is for the pressure and the other is for the travel. Assuming that the travel adjustment is properly adjusted...
On a cold day things are a little tighter and it "wants" a little more downwards pressure to complete its cycle. Sorta like me in the morning -- I need a little coffee to get going on a cold morning.
Adjust the down pressure/force just enough to make the unit close properly. Do not over adjust the down pressure or you will find it won't stay closed. Sometimes the manufacturer doesn't make it too clear where this adjustment is, but you should be able to find it if you look around.
I have seen units that were installed for years all of a sudden need a little tweak of this adjustment.
Good luck
Mar 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER
Refer to your owners manual to adjust the travel limits to stop the door opening too high
Apr 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
104 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
