Question about True 49 cu. ft. / 1388 liter Commercial Freezer GDIM-49NT
Bulbs in door wont last - True 49 cu. ft. / 1388 liter Commercial Freezer GDIM-49NT
  • 6,993 Answers
I don't think there is anything wrong with your freezer, maybe the bulb's quality is low that's why it does not last.
Also, the bulb might not last as a result of irregular power supply or power outage.
Either of the above is the reason why the bulbs in your refrigerator won't last.
Take care.
Posted on Oct 06, 2010
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
My appliance bulb in the freezer keeps burning out. The most recent one burned out within 48 hours. What could be the problem?
Could be the sudden temprature change of the filiment when you open the door and then when maybe slam the door?
Jul 25, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Light will not go out when door is closes
It sounds like the door switch is sticking in the on position to me>
Does it go out if you manually press door switch with the door open?
If it doesnt then its almost certainly a sticking door switch. You may have to bring this unit completely out of the fridge to look at it and then test it for a permnanently closed contact.
Mar 05, 2013 | AEG 10.35 cu. ft. / 293 liter Upright...
Inside light bulb quit working the bulb is good but doesn't turn on when door opens
Hello Rick Cieri - From what you have described it seems like the unit could possibly be experiencing a wiring failure or communication problem coming from the main control board. Connect with a certified technician to accurately pinpoint any potentially more serious issues.
Jan 19, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Door on new Kenmore freezer hard to open ... could this be a leveling problem? I wouldn't think it is an ice build-up problem since the freezer was only installed last Friday (9/24) and the ice maker is...
Check thoroughly for any obstructions, shipping tape, remaining pieces of plastic, in and around the doors, door frame, cabinet frame that the door contacts when closed, and around the upper and lower hinges. Do you hear any noises when opening or closing the door? Do you see the door rubbing on the inside liner as you open or close the door? Were the doors removed and replaced in moving? This last one, if it is the case, check the alignment at the upper hinges, loosen but dont remove the screws, and adjust the door away from center.
Sep 30, 2010 | Freezers
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Jun 15, 2009 | True 23 cu. ft. / 651 liter Commercial...
Need to change the lightbulb located on the freezer door. Do I turn the bulb counter clockwise or opposite?
Right-tighty, lefty loosey...that would be counter clockwise to remove, clockwise to insert. If the bulb is stuck, you may have to defrost the freezer (I know this sounds a bit extreme) to get it out easier. You may have some ice crystals keeping it lodged in the socket.
May 04, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Servis fridgefreezer light
IT COULD BE A BAD LIGHT SWITCH, SOCKET OR BULB.
IF THE CONTROL IS ELECTRONIC, SOME REFRIGERATORS WILL SHUT DOWN THE LIGHTS IF THE DOOR IS LEFT OPEN TOO LONG.
BE SURE THE BULB IS SCREWED IN ALL THE WAY. SOMETIMES, THEY WILL WORK LOOSE.
Apr 02, 2008 | Freezers
True 49 cu. ft. / 1388 liter Commercial Freezer GDIM-49NT Logo
35 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
