Question about Alesis Monitor One Mk2 Speaker
When ii turn the speakers on the blue light just keep flickeriing band no sounds is coming through
    Sergeant:
  • 198 Answers
Check all connections and also make sure the polarity of your speakers are correct,(+ to + , - to -), look to see if you have used the speaker output for sound also. Sometimes the plugs look the same but go to different outputs.
Posted on Oct 06, 2010
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
The speakers don't work at all. The blue light goes on fine, but there's no sound. They used to work fine with my iPod and iPhone, but not anymore.
Hi, Have they been turned off?
These speakers have a habit of setting their volume level to zero if the power is removed.
At the bottom of the right-hand speaker you should see some tiny volume up/down buttons.
Try pressing the up and see what happens.
May 05, 2011 | Harman Kardon Harmon Kardon SoundStick II...
My soundstick subwoofer won't turn on.. the blue led light is not turning on and no sound is coming from the speakers.. the black box that connects to the power is on, though... please help!!!
Has the same problem. Note: There is a powerswitch on the subwoofer! Pust on the volume knob and the system switches on and off. Hope this helps anyone else.
Apr 13, 2010 | Harman Kardon SoundSticks II Computer...
These speakers are not turning on anymore even
Wow! CNet reviews seemed to like those speakers.
Ummmm make sure the power is plugged in and you are in fact getting 110vAC where it is plugged in. If you have a DC voltmeter (or multimeter) you could test for the rated DC voltage coming out of the power brick that I'm sure it uses for power.
Other than that... are they in warranty still? You might want to seek a warranty repair. Probably not worth a non warranty repair ... unless it's something simple like the DC power brick adaptor thing.
Nov 23, 2009 | Harman Kardon SoundSticks II Computer...
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
No sound from subwoofer
You're in warranty. Appers to be a common problem. Soundstixks should either tell you how to fix it or replace your system.
Mar 03, 2008 | Harman Kardon SoundSticks II Computer...
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
May 09, 2007 | Infinity BassLink II Car Subwoofer
Alesis Monitor One Mk2 Speaker Logo
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
