Question about Whirlpool Kitchen Ranges
My whirlpool oven stoped making heat. Lights and blower motor works but no heat
DID YOU US SELF CLEAN MODE? IF SO CHANCES ARE YOU HAVE A BLOWN FUSE ON THE BACK OF OVEN. PRETTY EASY FIX.
Posted on Oct 07, 2010
I have a 2001 blazer and it has. Heat but the blower will not co e on
find the blower motor on rt side under the glove box remove kick panel and hit the blower motor with a hammer if it starts working you need a new blower motor start there
Feb 15, 2015 | 2001 Chevrolet Chevrolet Blazer
The microwave heats up fine but the blower motor does not come on right away. After a couple of minutes you can hear the motor start - stop and at the end finally works fine.
rheire could be a number of reasons for this problem i would start by checking the connections to the blower motor may just be loose connectors that dont make a good conection until heated up then check for power to the motor when unit is opperating if none it will be in the control panel if power is present replace motor.
Mar 08, 2011 | Maytag Appliances Over-the-Range Microwave...
Philips whirlpool oven the oven is heating but not well. There is a blower but the fan does not move. The display in fromt appears to be working and the grill works. Had two engineers out one said fan...
If the fan is in the center at the rear of the oven where the element is, and the element is working o/k, then I would say that there is no doubt about it being the fan motor that is faulty.
The fan and element come on together as they are both fed together.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Philips Ovens
Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
I have a 2000 olds alero and first the back
It sounds like an electrical nightmare. The rear defrost and the blower motor are probably not related. The fact that the blower motor only runs on high is because the blower motor resistor is bad. I'm guessing the blower motor is just worn out that's why that quit. As far as the turn signal problem, not a clue there, maybe a bad ground somewhere or you're getting feedback from another circuit. Electrical problems are tough enough when they're right in front you, let trying do solve them via email. You need an electrical wiz for a mechanic.
Jan 04, 2010 | 2000 Oldsmobile Alero
The blower stoped working in my 1999 astro, no heat, no air, no nothing. is it more than likley the blower motor?
Yes and No. They like to burn up the resistors, swithes and blower motors! You will need to trace it down. See if you have power at the blower motor, if not then start working your way back. It's alot easier to get to if you pull the coolant and washer resivor's out, then you have good access to the blower and resistor!
Nov 01, 2009 | 1999 Chevrolet Astro
My heater fan as stoped working on my bmw320 d it has climate control but all lights are fine
Hello There
I'd suggest looking at the fuse to start with, This is the cause in most cases.
Hope this helps
May 08, 2009 | 2007 BMW 335i Coupe
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
