Question about Frigidaire Refrigerators
Is a refrigerator usually plugged in to a GFI outlet that's connected to multiple other outlets? Is it mere poor practice or should it never be done?
    President:
  • 834 Answers
A GFI outlet (Ground Fault Interrupt) is actually designed to provide extra protection from electrocution in wet areas where water can come into contact with a hot wire, and as long as the refrigerator is plugged directly into the GFI outlet and is not plugged into the GFI outlet by using any extension cord then there should not be any problem as long as the GFI outlet is not over-loaded with other appliances or large electrical demands. If the GFI outlet is tripping then either there is a faulty appliance or electrical device plugged into the GFI outlet or the GFI outlet is simply over-loaded with too much electrical demand, or the GFI breaker could be faulty. Plugging a refrigerator into a GFI outlet is not bad practice, however over-loading one is and that is what should never be done.
Posted on Oct 06, 2010
Is a house plug with a cfic braker light suppose to be red or green
Most are green when functioning properly. Many have no lights at all. Try depressing the reset and see if the outlet works again. If not there are other things to look for. Often times one GFI outlet feeds multiple more outlets from the "load" connection on the back side of the GFI. If there is something wet, overloading the rating, or something with a fault in any of the outlets multipled off the single GFI it will trip. Disconnect all devices then attempt to reset. If that doesn't work and you possess some electrical skills pull the GFI outlet and disconnect the wires going to the "load" connection (While power is off) Re-energize and attempt to reset the GFI Outlet. If it resets your problem is beyond that outlet in the circuit of what you disconnect. You may not have found all the affected outlets. FYI if you have a 15amp GFI the rule of thumb is you can put more devices on outlets working off or through the GFI that add up to more than 1500 watts. If it is a 20amp GFI a quick rule of thumb is no load over 2000 watts. Space heaters, blow dryers, and hair curlers are often 1800 watts each. One alone and can trip a 15 amp GFI.
Dec 28, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
Used Beverage-air MT27, trips GFI breaker when I plug it in. I tried to isolate the short - unlplugged the top light ballast, switch, fans... The guy I got it from says to be sure to connect the ground...
I've seen refrigerators that are working fine blow GFI outlets when the compressor starts, usually just change to non GFI outlet for fix. You say its tripping GFI breaker , is there anyway to test it on non GFI breaker?
Jun 24, 2011 | Beverage-Air MT27 Beverage Cooler...
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Is a refrigerator usually plugged in to a GFI outlet?
It is not good practice to use refrigerator on a GFI. it is not that it wont work but every time a gfi trips it is degraded. GFI can also be daisy chained up to 4 other plugs can be conneced to it if the electrician wired it that way.
A refrigerator is suppos to be on a dedicated circut.
Oct 06, 2010 | Refrigerators
It keeps tripping a GFI outlet
GFI outlets tend to wear out very quickly with a refrigerator running on them,most Manufacturers do not recommend plugging any major appliance into a GFI outlet.If you plug it into a non GFI outlet and it works fine the problem is in the outlet.
Sep 06, 2009 | Refrigerators
Ge side by side refrigerator trips GFI
Try an extension cord to get it off the GFI outlet .
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Jan 24, 2009 | Refrigerators
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
The fridge keep tripping the GFCI. I reset it and one minute later it trips again. I even tried it on a different GFCI circuit, still trip. Thank you
Refigerators should NOT be on GFI-protected circuits. Problems have occasionally been reported when plugging a refrigerator, freezer or other motor-driven appliance into GFI-protected circuits. These appliances generally have a motor that pulls significant startup current. Due to the electrical characteristics of motors, the startup current can look like someone getting electrocuted, causing the protection system to trip. The best remedy is to connect these appliances to a non-GFI outlet. Usually outlets that are expected to serve such appliances will not have GFI's installed.
Apr 19, 2008 | Refrigerators
Refrigerators Logo
323 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
