Question about Dell Latitude D505 Notebook
Dell battery my dell latitude d505 won't charge the battery
  • 65 Answers
Bring it in the Geek Squad they can test your charger there, If the charger is ok send the whole pc to dell so they can check all the componets, charging unit might need to be replaced or you might have a short in the motherboard...
Posted on May 28, 2008
When i run my dell latitude d505 on the battery the screen dimms
click on the battery and go to more power options and there you can change the time on the screen to dims or just disable it to do nothing
Apr 27, 2014 | Dell Latitude D505 Notebook
Dell latitude D505 battery not charging
Take Dell latitude D505 battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Mar 31, 2013 | Dell Latitude D505 Notebook
Replacing cmos battery
Dell Support > Latitude D505 > Service Manual,
http://support.dell.com/support/edocs/systems/latd505/sm/index.htm
Reserve Battery
Regards,
joecoolvette
Oct 10, 2012 | Dell Latitude D505 Notebook
When I plug in the power cord to charge the battery, the light on the cord goes off. I tried several charges and they work. Can charged battery on another computer and place on the dead computer and it...
There's no fuse problem with that computer, try this first, Plug in the charger to an outlet don't plug it in the laptop, if the light on the charger turns on, then the charger is working try to plug it on the computer if the light on the charger goes out there's a problem with your motherboard. Contact the tech support for that so you can get that part replaced.
To double check try to use a known good charger if it works then you'll need another charger if not, Then contact your tech support for your dell make sure you still have a warrant.
Hope this helps!
Feb 15, 2010 | Dell Latitude D505 Notebook
Latitude d505 not charging
Your laptop isn't dying....it just means the battery is shot and it's time to get a new one...the laptop should be fine with a new battery. I recommend Ebatts.com if your going to order one online.
Jan 20, 2009 | Dell Latitude D505 Notebook
Dell Latitude D505 Notebook Logo
128 people viewed this question
Alun Cox
