Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
When the power switch is flipped the breaker on the outlet trips.
  • 4 Answers
Element blown - known problem on 1st and 2nd generation machines - www.craystoneshop.co.uk provide spare parts worldwide (outside the UK, you need to request price with shipping at info@craystoneshop.co.uk )
Posted on Jan 21, 2011
    President:
  • 1,618 Answers
Sounds like a bad element to me, check resistance on the element.
Posted on Oct 06, 2010
No power in back bedroom
Locate your circuit panel, and check your fuses/circuit breakers.
Maybe breaker tripped?
To reset, remember: All the way to OFF position first, then flip towards ON.
Jun 09, 2015 | Televison & Video
Wiring outdoor motion lights (with 14/2) to a nearby outlet (possibly 12/2)that has power. After wiring into outlet and turn on breaker, I lose power, but don't trip the breaker?
First take a cord and hook it to the motion lite and make shure it works .Remember that it only will work at night or dark area and you have to have lights in the fixture to make the contact.and make shure the plug is not on a dimmer or the wires are flipped. WHT. To the common side and black to the darker side and it has to be grounded .exspeacily if it is a led fixture.
Apr 01, 2017 | Cooper Wiring Devices Motion Sensing...
Breaker in garage flips after installing new 3 way switches and outlets
go back and check the wire colors on the devices that trip the breaker
Oct 21, 2013 | Electrical Supplies
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Our tap leaked and water got into the electrical part of the machine which now will not turn on. We have allowed it to dry out, is there a switch we can flip to reset the circuit breaker?
Inside your breaker box usually its marked. If not check breakers to see if any are tripped. If non seem tripped your going to have to go one by one. Plug light into outlet to see if it works first. If it dont proceed to test each breaker individually. If it does light up than you have a problem with your washer not the outlet. Also if you have a meter to test the outlet to see if you are getting power. Please contact me back and let me know if the outlet has power. Also please include Make and model of washer also model number of washer. Thank you
Jul 18, 2011 | Washing Machines
One year old Danby dac8075ee, HAS NO POWER, what could be wrong ? please help
your air conditioner has no 'power' on it's own. It must get the power from an electrical outlet.
It is possible that the outlet you are plugged into is 'dead,' i.e. not working. One simple way to test this is to plug in another electrical appliance, hair dryer for example to test it and see if it's working.
If you do this and the other electrical device works then you know your AC is getting the 'power' it needs to operate - in which case you have a problem with your AC, and will probably need to call a Service Tech.
If, however, you plug in another device and it - too - does not work then you know the problem is within the outlet, probably a 'breaker' that is off or has tripped off. So, you need to locate the breaker - box.
This "breaker - box" (in most houses) will be located in the garage, utility room, or behind a door somewhere in the house, i.e. kitchen or bedroom.
If your outlet is not working - just go to the breaker box and open the door and look for a breaker (looks like a light switch) that is in the off position or perhaps half way off and half way on. Once you find this breaker - be sure your AC is plugged in and - just flip it (breaker switch) back in the "on" position.
Note: if the breaker switch trips right back off - then you know you have a direct short in your AC and probably will need the help of a Service Tech.
If this is the problem and the breaker stays in the on position and the AC runs and cools - you are probably ok, unless the breaker trips again in a short time span.
If that happens you most likely have a problem in the unit although it's possible the breaker is bad - in any event you are probably in the need of a Service Tech.
good luck!
May 05, 2010 | Danby DAC8003D Air Conditioner
No power
If you mean absolutely no juice and haven't done so already, you need to check the breaker or fuse first. If the breaker/fuse is off flip the switch and try the oven. If the fuse trips again, you have a short someplace.
Obvious places would be the cord and outlet. To check these, turn the power off again and pull the stove out. Follow the cord and check it for broken areas areas. Then look at where it connects to the stove. Check the outlet and make sure that is intact.
If you see no problems with the outlet, the easiest way to check it without a tester is to simply plug another device into it.
Dec 23, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Jul 11, 2009 | House Brand Dryers
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
134 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
