Question about Lexmark C544dn Laser Printer
Error code 900 Lexmark c544dn network printer
    Genius:
  • 1,018 Answers
900 errors usually point to fuser or fuser related component failure.
Please have the printer serviced.
Posted on Oct 06, 2010
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Aug 14, 2008 | Lexmark Office Equipment & Supplies
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
Lexmark printer c544dn. The printer is saying to "82 Replace waste toner box"
Please click on the link http://bit.ly/psOcDA to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
May 10, 2011 | Lexmark C544dn Laser Printer
When trying to print, says "busy" then it say
This is a software error within the printer. Contact the manufacturer, as you likely do not have the equipment or expertise to fix this.
Feb 07, 2011 | Lexmark C544dn Laser Printer
How do you clear an error 82 message on a Lexmark c544n?
bjr mon imprimente lexmarkc544n elle fonction plus elle ma sorter 900frimware error je voudrais resoudre le problem svp esque si possible de maider
Feb 04, 2011 | Lexmark C544dn Laser Printer
LA IMPRESORA LEXMARK ME DA EL ERROR 122.05 SERVICE
Por favor, haga clic en el enlace http://bit.ly/rimqevpara obtener instrucciones sobre cómo hacer el procedimiento.Para obtener asistencia adicional, póngase encontacto con asistencia técnica de Lexmark.
Feb 02, 2011 | Lexmark C544dn Laser Printer
Lexmark C544 error code 82 replace waste toner box will not clear after last firmware update
Try to reseat the waste toner box and power down the printer for at least 30 seconds.
If you need further assistance, please contact Lexmark Technical Support Center
Jan 14, 2011 | Lexmark C544dn Laser Printer
What does 900 Service RIP Software error message mean and how do i reslove it
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Aug 02, 2010 | Lexmark Optra T610 Laser Printer
900 service error with lexmark printer
OK, a couple of things... Some earlier Lexmark units had code on both a RIP board (raster image
processor) and an engine board. In this case, the code would have to be reloaded into both
boards. Fortunately, this can be done even if the printer will not boot to a ready state. However, if
this has already been done sucessfuly, the problem may well not be the printer but rather something
in the data stream. To confirm this, remove any and all data cables and reboot the printer. If it comes ready and you can print all the internal pages including the network config pages, then it is likely the
problem is the data stream. One must be careful when the printer is controlled by a print server
because the end user may not have control over the print que. If a corrupt or printer incomprehensible
job is stuck in the que, the printer will go to a 900 condition as soon as the network interface
initializes. This will continue until the print que is cleared.
Hope this helps...
Sean.
Dec 13, 2007 | Lexmark Optra T620 Laser Printer
Lexmark C544dn Laser Printer Logo
628 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
