Question about Health & Beauty
I need a manual for Medline Enduro 2 Oxygen Concentrator so I can figure out what service requirements are. Thank you
  • 4736 Answers
SOURCE: My wife and I are
Yes, it could be done. But, since 2 people would using it at the same time, it would require raising the flow to 4 liters. To accomplish this, you will need a 'Y' connector for the tubing. Plus, one short piece of tubing to come off the concentrator for the 'Y' connector to connect to. Then connect each cannula's tubing to the 'Y" in the 'Y' connector.
Hope this helps you out.
Posted on Feb 14, 2011
lostinfamily
  • 149 Answers
SOURCE: Need Users Manual for Millennium Respironics M605
http://www.pulmodata.si/PDF%20prospekti/Millennium.PDF
Posted on Mar 18, 2009
SOURCE: I need instructions for DeVilbiss 5 ltr. Oxy Concentrator
I believe I can, Please contact me at
hollyg916@yahoo.com In subject put oxygen. will be looking to hear from you.
Posted on Jun 04, 2009
  • 31 Answers
SOURCE: Hello: I have a Devilbiss 5 liter oxygen
I can send you the filters but it needs to be analyzed which can only be done onsite. A small local independent DME dealer would check it for you. You just have to call the right one.
Posted on Jun 27, 2010
mcdevito75
  • 1970 Answers
SOURCE: I need a manual for an Invacare oxygen
mcdevito75 here, You can try online at Invacare.com You can also check with any surgical supply outlet in your area.
Posted on Jul 02, 2010
Alliance Healthdyne oxygen concentrator alarm doesn't stop when turning the unit on.
There are parts inside that machine that have fixed hour ratings. When they are needing to be replaced, that machine has to be serviced. Since it is not an over the counter device, you need to contact a medical specialty vendor and have it worked on. There is no parts available.
Mar 28, 2013 | Air Purifiers
P-B Companion 590 Oxygen Concentrator is beeping. What should we check and fix to repair the unit? Can you provide a link to the manual or troubleshooting guide for this unit? Thank you for your...
When these units are beeping it indicates they are basically not running. So you first need to ensure who ever is using it has access to o2 if they require. There isn't much you can do to fix these at home. You can first try going over the following. Not really that helpful but might help you sort it out. If you can't spot anything obvious ie unplugged no power etc then first contact anyone local such as the medical supply place. That would get you the fastest repair or help. If you don't have one of those to call then don't be afraid to call the 1-800 number below and ask the company.
The local company or even your doctor might be able to help you get bottled O2 while your unit is getting fixed.
If there is an audible alarm -- concentrator is not running: • Is unit plugged into a working outlet? • Check circuit breaker -- Right side of unit, behind a small door on the Companion 590 and 429a -- Back of the unit on the Companion 492 -- Between the on/off switch and flow meter
If there is an audible alarm -- concentrator is running: • Concentrator cannot be fixed by consumer • Call 314.362.0720 or toll-free 800.456.9366
There is a visual alarm on the Companion 590 with oxygen concentration indicator: • Green Light -- Normal -- Oxygen concentrations are correct • Yellow Light -- Below Normal -- Oxygen concentrations have fallen below an acceptable level • Red Light -- Not Operating -- Oxygen is no longer being produced; audible alarm will sound and concentrator will shut down
Apr 04, 2011 | Health & Beauty
DEAR SIR whether we canUSE CONCENTRATOR devlbiss 515 AKS CONTINUESLY MONTHS TOGETHER WITHI OUT SWITHCH OF. HOW MANY VOTS CAPICTY INVERTOR REQUIRED TO RUN THE SAME DURING POWER FAILUE
if you run the system for 5 hours if you give a gap of 1 hour then the machine life will be good and you can use the system whole night no need to switch off ,and 1kv Online ups is required and batteries dependin on hte backup u require.
if any doubt
mail me deltazameer@gamil.com
Mar 25, 2011 | DeVilbiss 5 Liter Oxygen Concentrator with...
My wife and I are both on oxygen at night at a setting of 2, can we use the same concentrator, if so how ?
Feb 14, 2011 | Health & Beauty
Hi I'm using the devilbiss 5 lts Oxygen concentrator from past 4.5 years. Recently from past 2 months it is giving some problem, during night while using machine within 2 hrs it is showing low oxygen (with...
please check if the model of Concentrator is 515HKS or aks if u have any idea to open the screw it can be very easily opened ,check if the fan which will be under compressor is running ,or any leakage from the tube point which starts from the copressor or there will be muffler connection to the compressor which will be ball shaped,
if u have any doubt after checking with this please mail me to delltazameer@gmail.com
Jan 03, 2011 | DeVilbiss 5 Liter Oxygen Concentrator with...
Hello: I have a Devilbiss 5 liter oxygen concentrator (Catalog #515D2) that I bought from an individual who used to work for a medical )2 company. He used to get filters and service it for me, but has...
May 11, 2010 | DeVilbiss 5 Liter Oxygen Concentrator with...
Other than not passing or producing oxygen flow is it possible for a concentrator to produce carbon monoxides or other gasses? After looking at and reading the information provided on your site it seems...
You are correct. This concentrator is oxygen specific. Therefore it only concentrates the oxygen, not other gasses. Joe
ps please rate my answer as very helpful.. thanks
Mar 29, 2010 | DeVilbiss 5 Liter Oxygen Concentrator with...
May 25, 2009 | DeVilbiss 5 Liter Oxygen Concentrator with...
Health & Beauty Logo
386 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
