Question about Maytag Washing Machines
My washer says f21 - Maytag Washing Machines
  • 5,911 Answers
If this is a Maytag Epic series FRONT LOADER, "F21" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. On some model washers there is no screw off cap on the pump and you will have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Removing the inlet hose for inpsection is recommended on all these washers just to ensure there isn't anything lodged in the line. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: The washer will not complete a wash cycle until the conditions causing the error are corrected. In addition, a "SUD" or "SD" (Suds lock) error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Posted on Oct 07, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
What does the code F21 mean on my washer
f21 is long drain error exceeding 8 mins check drain hose for clog or filter on washer at drain pump also remove hose from tub to pump check for blockage
May 13, 2011 | Kenmore Elite HE5t Washer
Whats f21 mean?? a new belt??
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time, the belt is a non-factor.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry.
Regards,
Macmarkus :)
May 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is an F21 flashing? My washer will not turn off or anything. It is humming and flashing F21. Thanks
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
F21 showing on screen
Take the bottom panel off of the washer and there should be a instruction guide in the washer that will tell you what the error code indicates.
Apr 01, 2009 | Washing Machines
Washer don't work (F21) message
The "F21" error is a "Long Drain" error code. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If you still require assistance, please let me know.
Jan 07, 2009 | Kenmore 46462 Front Load Washer
Washing Machines Logo
210 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
