Question about Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work at all. I've tried using different outlets just in case it was a power source problem, but it still didn't work. I typically use it to make a smoothie. I miss my blender - Help :)
  • 3 Answers
Sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Posted on Oct 06, 2010
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
I have a magic chef MCO165UB that the LCD display is black on and the oven won't operate at all. I've checked the fuse and it ohms out. I checked across the Bottom T.C.O. and don't get con
Sometimes that is a fan switch to turn on the blower if it gets too hot when cooking on the stove top. But you say the schematic shows it should be closed. So jump it and try the unit. if it works OK then replace it.
Oct 16, 2017 | Microwave Ovens
GE microwave fan turns on when door opened
The problem is caused by one or two bad door switches.
Apr 27, 2012 | Microwave Ovens
Kenmore microwave fan won't shut off
The fan is required when the microwave is running, cools the magnetron. The problem may be in one of the interlock door switches, it is to complicated to go through the steps and the testing requirements, plus the alignment is critical.
Mar 22, 2012 | Microwave Ovens
Interior light bulb burned out previously; now no power at all.
I have had to change the fuse in a handful of my microwaves,usually when they get to be about 10 years old.If you take the housing off,you should find an inline fuse holder on the power cord just as it enters the housing.Read the info on the fuse,and replace it with the same size/type(the ones I've seen are ceramic fast acting fuses)I also like to take another spare and tape it inside the housing near the fuse holder so I don't lose the spare.
Jan 01, 2012 | Magic Chef Jade Microwave Ovens
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
I purchased a G E single serve blender...used it once, now the blade base will not fit into the blender base...what would cause this to happen?
The problem may be that the base is not turned all the way into the cup due to damage of the threads or the wrong gasket or having more then one gasket. This would keep the tabs from aligning with the notches in the base. Try the other base and cup and if that doesn't work then the notches may be the problem. There may be some foreign object jammed in them
or they may damaged. Take a small screwdriver and see that the spring loaded ramps in the notches compress. GE's cusomer assistance number is 1-877-207-0923. These units have a 2 year warranty though I dont know about second owners.
Nov 21, 2010 | GE Microwave Ovens
GE PROFILE MICROWAVE LIGHT CONSTANT ON NOW
JVM1650SH - May 27, 2017
(I'm also sending this to your listed e-mail address, but with full details.)
I see (and repair) this problem a lot. The problem is on the controller assembly. Details here.
At my Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line.
Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 22, 2017 | GE JVM1650SH Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
