Question about SanDisk Sansa c200 MP3 Player
Sansa Clip mp3 player
Plug clip in computer registers player then says there is a fault and the device will not work properly. Tried your other solutions and they didn't work. Basic problem computer does not 'see' mp3 player. It is also taking an age to charge!
  • 8,596 Answers
Use the volume + (somtimes you can use REC instead) method to force the computer to recognize the device. Sometimes requires a restart of computer after your initial attempt.
Substitute "volume +" for "REC" if need be:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 28, 2008
My computer does not recognise my sandisk sansa clip.i dont have a driver and i have windows xp.what to do?
Have you tried the following unplug the USB cable, lock the device, push the round button in the middle of the Sansa player, and while holding it, plug in again the USB cable
May 29, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
How do you put music on the SanDisk Sansa Clip MP3 Player
1. First, you have songs saving in your computer.
2. You have 2 ways to put music on the Sandisk Sansa Clip:
2.1. Plug device into computer, Drag and Drop music from your computer into "Music" folder of the Sandisk Sansa Clip.
2.2. Use Windows Media Player in your computer to transfer songs to your device; Plug device to computer, open Windows Media Player, click on Sync tab, drag and drop music into "Drag items here " on the right side of the windows media player, click on Start Sync button.
Good luck
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa clip mp3 player doesn't get detected
Trying:
1. Update Windows Media Player 11 for computer
2. Get in Device Manager, right click on icon device and anable it.
Good luck
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
Wont install with installation disk without internet
GO ONLINE!!SANSA.COM AND THE WILL LET YOU DOWNLOAD THE HARDWARE.THE SAME THING HAPPEN TO ME!!
Jun 02, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Computer wont recognize sansa clip mp3 player
Reformat clip with disk utility after looking at it like an external disk. Do this by turning it off. Puting it in lock mode. Hold down middle button as you plug it in.
I am mad at my Clip as it did the same thing.
Screen shot here:
Sansa clip not recognized.
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player 2GB shows as UNKNOWN DEVICE when i connect
Sandisk website will have it, and will have the vista compatible software:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
here is the link for the sansa updater.
Ok...here is something you might want to do....I know you already formatted your device a zillion times already but please do it one more time using the Format option under Settings menu in your device....then restart your computer....then plug in your computer again after restarting to see if it recognizes now.....if not...here is one thing you could do....go to this link
http://www.nirsoft.net/utils/usb_devices_view.html
download the USBDeView software and see if the registry has the player in there....select it and delete it and then plug in your PC again to see if it will re-register the device and works...hope this will help.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
To help you with that, I need to know what operating system your using (XP, Vista, ect...) and what other devices you have plugged into the computer. There are a few things you can try. When you plug it in, does it say it's connected? Does the "Found new hardware" wizard come up? Let me know, I'll see what I can do to help
Dec 31, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
