Question about Logitech Harmony 360 LCD Remote Control
Logitech 360 remote /samsung 52
Remote display safe mode. Would not function after that. Changed the batteries and now the remote does not work to start or turn off tv or change stations.
Please help
Tadly
  • Anonymous Jan 23, 2009
    I have the same problem mine says safe mode and changing the batteries and press all the buttons does nothing.
Hi. Here is how to get your remote out of safe mode.
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this helps.
Posted on Mar 06, 2010
How to reset harmony 650 for 'system error!' ?
If your remote is not behaving properly, you can reset it. To do so, remove one of the batteries, hold down the All Off button, and reinsert the battery. A message will appear on the remote screen indicating that the remote has entered safe mode. Next, connect the remote to your computer and sync it. The remote should now be updated and functioning properly.
May 12, 2014 | Logitech Harmony 650 Remote Control
I have a Harmony 1000 remote and it will not work out of the cradle i changed the battery and it still doesnt work
Hi! You should try to update the firmware in safe mode:
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
If it does not go into safe mode, or the firware update will not complete then it's probably a hardware issue. If you're in warranty you can call Logitech for a replacement.
Mar 09, 2010 | Logitech Harmony 1000 LCD Touchscreen...
Harmony 890 remote has no display but still has functionality
Hey!
I had this same issue with my Harmony Remote. Logitech sent be these steps and they got it working right!!!
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting.
2) Ensure you have the latest version of the Harmony Remote Software (7.7).
3) Update the firmware on the Harmony Remote. The following link shows how to complete this task:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this:
a) Remove the battery from the Harmony Remote.
b) Press and hold the power button while reinserting the battery into the Harmony Remote.
c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
I hope this gets the display on your Harmony Remote working too!!!
-Kennedy
Oct 07, 2009 | Logitech Harmony 890 LCD Remote Control
It says safe mode
Hey!
I got my Harmony Remote stuck in safe mode and found the following link that got it working properly!!!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
I hope this helps!!!
-Kennedy
Aug 05, 2009 | Logitech Harmony 550 Remote Control
Logitech Harmony universal remote stuck in safe mode
Just a message to all that have problems with there Logitec remotes. My remote went into something called a "safe mode" when my partner changed the batteries while holding the power button.... I pressed every single button to try and get out of it but nothing seemed to work, (I was getting pretty frusterated, there is nothing in the manual to tell you how to fix this problem), however, I have now learnt that as you replace the batteries you need to have the number 2 button held in as you replace the last battery. This works 100% so if you have any trouble with the "safe mode" then this is what fixes it.
Carly.
Jul 14, 2009 | Logitech Harmony 520 LCD Remote Control
My harmony 550 remote is in Safe Mode and will not respond to any button I push. How do I get my remote to work again?
Did you try this response from the Logitech users' forum? It can't hurt to try since all your settings are stored on the web, not on the remote.
http://logitech-en-amr.custhelp.com/...i=&p_topview=1
Basically, Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
1. Ensure the Remote is in "Safe Mode Requested" by taking out the batteries, and disconnecting the remote from the USB cable.
2. Hold down the Off button and plug the remote into the USB.
3. Continue holding down the Off button for another 10 seconds. The remote should then display the words "Safe Mode Requested".
4. With the unit in "Safe Mode Requested", re-install the firmware by clicking Support on your home page.
5. Click Firmware in the Downloads section and follow the online instructions to upgrade the firmware.
6. Once the firmware upgrade is complete, click Update My Remote.
7. Insert new batteries into the remote.
Jun 15, 2009 | Logitech Harmony 550 Remote Control
Logitech harmony advanced universal remote 550 display safe mode
remove the batteries2.gif from the remote
hold down to the number 2 key
as you are holding down to the number 2 key (do not let go of this number key) put the batteries back in
now remove the batteries again and put it back in again without pressing any buttons
if this does nto fix the issue
remove the batteries from the remote
do a firmware upgrade
Apr 04, 2009 | Logitech Harmony 966208 Remote Control
Display shows: Safe Mode!
To get your 550 out of safe mode, follow these steps. 1. Remove the batteries. 2. Hold the '2' button down. 3. While still holding the '2' button down, replace the batteries. 4. The remote will boot into the normal functionality. Note: If the 'Off' button is held down while inserting the batteries, the remote will boot into 'Safe Mode'. Also here for manuals: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=logitech
Mar 26, 2009 | Logitech Harmony 550 Remote Control
Safe Mode
According to Logitech, If you remove the batteries, hold down the # 2 button and then replace the batteries that will boot the remote into normal mode. Also, holding down the power button while replacing the batteries boots the remote into safe mode.
Nov 26, 2007 | Logitech Harmony 360 LCD Remote Control
Safe mode
Sep 29, 2007 | Logitech Harmony 550 Remote Control
Logitech Harmony 360 LCD Remote Control Logo
125 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
