I have a Panasonic pt-52lcx15 At first the picture had discolored spots on the screen. I removed the lens & mirror holder lid & cleaned the lens which were caked with dust.Since I put it all back together & turned it on, the screen only dispays in blue but picture is working just no other color.
    President:
  • 2,777 Answers
Sounds like you now have convergence issues. I guess it was just a coincidence that it happened when it
did which is extremely unfortunate. I guess its possible somehow they shorted out or were bumped in the process. Check out this little link here for information on how to replace the convergence chips:
http://www.ehow.com/how_5487792_replace-projection-tv-convergence-chip.html
Posted on Oct 06, 2010
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
Panasonic, model # PT-52LCX15
you might have more screws on the bottom i strongly suggest you be very carefull doing this the sreens are very delcate and cost lots of money
Nov 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Tip
PANASONIC WITH FUZZY SPOTS
FIXYA TIP PANASONIC
I hope this not AN old TIP, but I still see it asked and not answered properly by some.
TIP:
PANASONIC:
MODELS: PT-44LCX65, PT-52LCX15, PT-52LCX65, PT-52LCX35,
PT-61LCX65, PT-61LCX35.
SYMPTOMS:
1. FUZZY SPOTS
2. FUZZY SPOTS WITH STAINS
3. FUZZY SPOTS & UPSIDE DOWN
4.. FUZZY SPOTS WITH LINES
5. LOOK LIKE BAD LIGHT ENGINE.
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM CORRECTION TOOL; (LSUQ0100).
It is an easy repair (about 7 minutes), it takes longer to take the back off to perform this procedure.
Can't be purchased unless you have an account, customers can not purchase.
Thanks, Big IRISH.
on Dec 15, 2009 | Dishwashers
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
There are color spots all over screen-pt-61lcx35
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses or one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Get an estimate -Be sure to vote/rate me if this helped Thanks!
Nov 06, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Refurbishing the 1080i-capable Panasonic 47-inch WS DLP
The tubes have a useful life of 3000 hours. Replacing those tubes is close to $3000.00. It's going to be cheaper to get a smart flatscreen TV. The minute you try to clean the mirror, you will put tiny scratches on it. There is no bulb in tour TV, There are 3 cathode ray tubes. There is a lot of high voltage (25,00 or more) inside the TV, so be careful poking around inside the TV.
Jul 11, 2017 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Dull screen
http://www.ehow.com/how_2036563_clean-lens-tv.html
Dec 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-52LCX15 green spot on screen
Easy fix. I had the same green dot problem and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
JK
Oct 04, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
