Car gets steamed up and the blower is not working the heater works ok
    New Friend:
  • 107 Answers
Check the blower fuse and make sure nothing is stuck in the blower.
Posted on Oct 10, 2010
Fan heater blower not working, car all steamed up and cold etc. Checked fuses but all ok, suspect relay but not sure where the location is. Maybe fan has had its days but want to rule out relay first! Can...
check the voltage at the motor connector. Easiest to start there. Could be a faulty motor (most likely part). divide in half to troubleshoot.. My money would be on the motor though.
Dec 23, 2012 | 2005 Volvo XC90
Heater and blower wont work and fuses are ok
will it blow air on any setting besides defrost
Dec 12, 2012 | Cars & Trucks
Type your problem for a solution..HEAT NOT BLOWING FUSE OK.
REMOVE HEATER BLOWER MOTOR AND HOT WIRE IT.IF HEATER BLOWER MOTOR WORKS WHEN HOT WIRED EITHER BLOWER RELAY BAD OR AC AND HEATER CONTROL SWITCH NOT WORKING.IF BLOWER DONT WORK WHEN HOT WIRED BLOWER MOTOR IS BAD.
Oct 25, 2011 | 1997 Nissan Quest
Worried about a blown head gasket. Just replaced radiator becuase of leak. have yet to change thermostat (soon) I am getting no heat to the cab. I have no symptoms of a head gasket blow out such as sweet...
If you are not getting white smoke out of the exhaust then your head gasket should be ok. You could either have a Thermostat that is stuck open which would not allow the coolant to warm up to give you heat or the heater control valve is not working properly and is not closing the flap that directs the blower through the heater core to give you heat.
Jan 07, 2011 | Jeep Grand Cherokee Cars & Trucks
My front defroster is not working at its best, however the back one is working properly. If I add any heat while trying to defrost my windows the problem get worst.
Sounds like the heater core is leaking coolant. If it is leaking it will blow steam out of defrost vents and fog the windshield. Symptoms: low coolant level in radiator, steam coming out vents when engine is warmed up, odor of anti-freeze coming out of vents, wet carpet in floorboard near heater blower motor.
If so, replace heater core.
Dec 07, 2010 | Ford Taurus Cars & Trucks
Steam comes out of vents, no heat, blower works, no air conditioning now since steam started coming out.
Dear Kaylornet,
It sounds like the sitiuation you have is a leaking heater core. When the car cools down enough,you need to check the coolant level in the radiator and the bottle. You can check the floor board (usually on the passenger side)for residue and under the car. Using a white paper towel, soak up the liquid and see if it is the same color as your coolant.If it is,the core is at fault. Not alot of people like to do this type of repair. If it ends up as the heater core and you want to tackle the repair,drop me a line and I will send you the steps to get it done. Thanks,Chuck
Jan 03, 2010 | 1994 Ford Escort
Heater blower stopped working all fuses ok
check the connections at switch and motor if good will need a volt meter or test light to check the switch and blower motor for power
Dec 26, 2009 | Nissan Pathfinder Cars & Trucks
Heater does not work. have tested the blower on
Ok very important that you verify if the valve that leads to the heater coolant if that does not open the heater does not work on most cars with empty comprovar this works if you have connected the hose to vacuum and makes it that opens the valve
Oct 18, 2009 | 2001 Dodge Dakota
Heater blower won't run on heat or a/c
sounds like blower motor is junk what hapens is people take the cabin filther out and all kinds of junk falls into heater motor and eventually it gets stuck and motor will not work right
Mar 09, 2009 | 1996 Volvo 850
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
