Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
How to adjust temp control for sigle lever shower control
    Sergeant:
  • 268 Answers
Temp control is only accomplished by moving handle to desired position. If your asking is the hardware that in behind the single lever going to allow for adjustments, then the answer is NO. I installed the same into one of my bathrooms several years ago and I know what I am talking about. The single handle on that type on mine starts off then cold to hot. Problem is I wait for hot water to max so I can adjust it down to a comfortable temperture to prevent being burned. I refuse to buy one for other tubs. The 2 handles make temperture much easier with less wasted water used until its hot. Remember if you decide to replace with a two lever model then you will have to replumb the pipes for a two handle hardware unit (thats the stuff behind wall that your single handle goes into to which is currently plumbed for a single handle hardware unit.)
Posted on Oct 06, 2010
  • John Howard Feb 07, 2014
    I used to have a shower door on my shower, but then it broke and I can't get the door bolted in there. I am having problems keeping the door to stay in the wall. http://www.careflections.com
How do I remove a Pfister Marielle metal lever handle?
Bear with me, please. Adjust the temp at the physical valve?
Interesting at the least. Never seen or heard of that. They come up with something new everyday. I'm going to follow this for my own benefit. Thank you. And good luck. - Ned
Jul 23, 2014 | Price Pfister Home
Adjust hot water on hansgrohe metro shower
The hand shower and wall bar does not control temp. The valve in the wall would control the temperature of the water going to the shower. I would need to be able to identify the model number of the valve in the wall to be able to give accurate instructions on temperature adjustment. If you need help identifying this valve feel free to give me a call at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough
Oct 13, 2012 | Hansgrohe 06496 Croma Hand Held Shower -...
How do I set the stops? with the valve close the white moval stop is against the the fixed stop - where should the black movable stop be when the valve is closed> Also what is the function of the stop -...
the white is a temp limiter stop...and the black is a personal temp setting...the white at max temp should be up to the brass stop and the black is adjustable to personal adjustments...good luck
Aug 28, 2011 | Danze D500558T Parma Shower w/ 4"...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Dec 25, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Single lever shower temp adjustment
there is a ring with teeth on it you should be able to rotate it
three or four marks off the center position to increase hot water
this is the only adjustment needed...good luck
Oct 31, 2009 | Home
I had installed a shower mixing valve with single lever and I had only cold water running and I wanted to test and did not work. does the shower only works when you have hot and cold water running
u have to adjust your anti scold to add more hot water most shower valves are shipped with cold adjustment primary. if still have install paperwork it will tell you how to adjust anti scold if not a remove the lever and u should see a red and blue plastic washer looking tabs those are your hot and cold adjustments slid the red one out and turn it a little counterclockwise and slide it back in place do this a couple of times till u get your hot water the temp u want
Sep 24, 2009 | Moen 3175 Legend One Handle Shower Faucet...
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
669 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
