Question about GE (PSS26MSRSS) Side by Side Refrigerator
GSS22jerfww ice dispencer?
Ice dispencer works intermittently/occasionally. when paddle is pressed to eject ice, the light dims and no noise is heard.
  • 770 Answers
Main Ctrl board bad WR55X10552 is the part you need the board has a short it is on the back wall of the unit I will bet when you press it in the compresser turns off as well !!!
Posted on May 28, 2008
Frigidaire Gallery series ice dispencer does not dispence ice. Also, what is proper freezer setting?
Thank you for your inquiry, friend!
Based off what you have described you are having trouble with your ice dispenser not dispensing inside of your Frigidaire refrigerator and you would like to know the proper temperature setting. You may want to open the door of your freezer and check your chute to assure that there are no ice chunks or frost causing issues with your ice dispensing. When you push on the paddle do you hear a noise? If you do not hear a noise your auger could be bas inside of your icemaker. If you hear a noise and no pushing it could be a possible problem with the motor. It is recommended to have your freezer on a zero degrees for a factory setting. I hope this information is helpful. If you need any further assistance please feel free to reconnect. -Matt
Feb 21, 2015 | Frigidaire Refrigerators
GE ICE MAKER, VERY LITTLE ICE,
I had this problem with my GE ice maker not working and it was an unbelievably easy fix. If you have the same ice maker then you will see a green light by the power switch. Below the ice maker is a "paddle" ice sensor. The paddle is attached to the ice maker and there is a coil type tension spring. If your paddle is loose, make sure the end of the spring (the pointy wire end) is inserted into a small hole. You probably can't see the hole but move the wire end until it pops into the small hole. You should now have tension on the paddle. At this point I had heard that the freezer light bulb may be drawing too much current for the ice makers motherboard. I removed the bulb and, UNBELIEVABLY, the ice maker began making ice! Try removing or replacing the LIGHT BULB first!
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refridgerator/freezer light dims when trying to use ice maker
check the ice bin to see if theres something binding the auger up. take it out and thaw it is so.
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
138 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
