Question about Zebra LP 2844 Thermal Printer
I have a Zebra LP 2844, I`ve installed all the drivers and i`ve switch the printer in the USB Port, At first, the printer wasn`t be recognized, after update the firmware, my computer recognize the device... but when i try print a page to prove... nothing, No work. Please Help, My SO is win 7 Pro
    Champion:
  • Zebra Expert
  • 285 Answers
Version of firmware?
driver?
Posted on Nov 25, 2010
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Can't get it to print from usb port
the usb port might be dead.... try LPT or DB9 cable . if you reallly need the USB then you have to change the Main logic board
Jan 13, 2010 | Zebra LP 2844 Thermal Printer
Lp 2844 will not work with my new laptop
You need a piece of software to create a Virtual com port, make sure you have the comms set correctly 9600, n, 8, 1 and print to that port, you will find it clearly marked in Device Manager. You can get a parallel to USB cable then you can use your driver set to LPT1
Nov 05, 2009 | Zebra LP 2844 Thermal Printer
My printer and computer are not communicating at
If the software is installed for the printer, there is only two things you can do.
Plug a USB device that's already working into that port. If it's working, It'll install the driver.
If it's not working, try another port. Change your USB cable to another one. Also, in the BIOS, set the USB port to high speed.
Aug 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
LP 2844 not working with Create-A-Label v3.04
If you are using CAL (Create A Label) you must have a device called a "Dongle" plugged into your parallel (or USB) port. This acts as the activation key for CAL. If there is no dongle then CAL only works in demo mode. That's why printer Icon stays grayed out. The "Dongle" normally plugs directly into the parallel port and one end of the parallel lead plugs into the "Dongle" while the other plugs into your printer.
I would suggest that you download "Zebra Designer" software from the Zebra Website..This will work without any activation.
If you use ZD you must use the correct ZDesigner driver. (Install automatically as part of ZD setup) This driver only works with ZD.
If you need to link to a database then you will have to BUY label software. Zebra Designer Pro, or Nicelabel, or Bartender....etc.
Oct 07, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 parallel communication problem
The printer is installed on the PC using a specific port. If it's installed on the USB port, it won't work on the parallel port. Do you have this printer installed 3 different times? Need more details such as how was it installed the first time? And if it's working on the other 2 ports, why does it have to work on the parallel?
Apr 15, 2008 | Zebra LP 2844 Thermal Printer
UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
Feb 21, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
787 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
