Question about Cisco (WS-X3011) Router
My network name changed on me from tall flamingo to cisco 31852 randomly yesterday and i cant log into it because it is locked. i put in my password before it changed that was with tall flamingo; it says the password is not correct. what do i do?
  • 1,679 Answers
Try this utility program and it should be helpful to provide you details about your router.
http://www.fixya.com/support/r5198336-details_router_or_network
Posted on Oct 06, 2010
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
How to a change password wifi cisco dpc2320
plug ethernet cable directly between a pc and router and then type in dos prompt ipconfig to find ip address of default gateway if this is the only router. Then note ip addressd it will be most likely 192.168.0.1 or 10.0.0.1 and put this into an internet brower url address box and you should be able to log into the router unless it has a password and user name set . Go may need to google the default user name and password for the router . go into wireless security settings and then you should be able to change the encryption key.
Oct 28, 2014 | Cisco Model DPC2320 DOCSIS 2.0 Wireless...
How do i access my port forwarding if my cisco router cant even log me in? are there preset defaults?
You can do a reset on your router. After the reset, the password goes back to the default, which is admin
Jul 22, 2013 | Cisco Linksys E1000 WirelessN Broadband...
Want to put lock on guest
Linksys E series routers can broadcast 2 wireless networks. First one is the main wireless network which is secured wireless network.
The second network is a guest network which will always show you unsecured.
It will never show you secured and you can not make it secured.
However it has a web based security.
Anyone can connect to the guest network but will not be able to access Internet without Guest access password.
In other words there is a security.
You can disable guest access also.
See more about Cisco Guest network access password
Mar 10, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Want to put lock on guest set up
open your browser to 192.168.1.1
default login/pass is admin
go to wirelessgo to wireless security and apply a password to your guest network.
Mar 10, 2012 | Cisco Linksys E2000 Advanced WirelessN...
What is the default enable Password for cisco 7604 - sup720-3b
The default user name and password for Cisco routers and switches is usually:
user name: Cisco password: Cisco
Make sure to capitalize the C's.
Mar 16, 2011 | Cisco 7604 Chas 4-slot 2 SUP720-3B 2 PS
There is no wireless connection and it says that the password may have been changed. It also asks for the key to be entered. What is the network key? How do I change it? How do I restore the assigned...
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here
for step by step instructions
Apr 12, 2010 | Linksys WRT160N Wireless Router
How do I change my SSID?
You log into your router and change it there in your setup. The SSID, is just the "Name" you give your "Connection"
Mar 01, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
Cant log in to my space
This is secure website issue --
I think when put your user name and password it kicks you back.
Solution --:
Try loggin on to safe mode with networking and see if it works fine if yes
your security software or firewall is creating a problem,hence disable the software and see if it works .
Nov 17, 2008 | MySpace Social Network
Computers & Internet Logo
175 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
