Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Transmission running eratic sometimes will only move in reverse. I have to move lever forward and back several time to get it to move forward.
  • 110 Answers
You can try an air purge 1st. Instructions for this can be found in your owners manual. If that doesn't help the trans-axle will need replacing.
Posted on Oct 25, 2010
The car has an automatic transmission and all of a sudden i had no reverse had no slipping or nothing the drive gears work fine no slipping grinding nothing shifts through all gears just fine
It may just need servicing/adjusting.
Your reverse gear is actually first gear ... when you select reverse another 'cog' fits into the toothed wheels to change the direction of first gear ... to give you reverse...
It may be a sticky valve or just a bit of adjustment (workshop job..) that is required.
What you can try ..
Start the car ... move the lever through all the positions several times (foot on brake..). Keep your foot on the brake and then put it in reverse and rev the car. Hard!
Try doing it several times.
An auto transmission works on valves opening and closing. Reverse gear - in comparison with the forward gears - is seldom used. The reverse valve can 'stick'. Try forcing it to open ... frighten it ... but keep your foot on the brake...
Jan 18, 2016 | 2001 Chrysler PT Cruiser
95 chevy k1500 i put the truck in 4 wheel drive and heard a grinding then the truck moved alittle bit and lost reverse. Then lost all forward gears. could it be the transfer case or tranny
it sounds like the transfer case is in neutral good test start truck place trans in reverse slowly try to place back in park if it makes any noise then the output shaft of transmission is turning then problem is in transfer case move that lever back & forth several times this might get it working again
May 08, 2014 | Chevrolet 1500 Cars & Trucks
Automatic transmission will not engage gear
Sounds like the transmission is gone .Check the fluid level ,and sometimes the filters inside the transmission gets clogged up.have it checked by a qualified transmission mechanic.
Jan 05, 2014 | 2007 Chevrolet Chevrolet Equinox LT
2003 Ford Escape car was in park and moved into reverse but car moved forward instead
Most transmission control lever with cable lock bolt become lose in time need to re adjust position to the right place and tighten the bolts ,it can easily done by jacking up the suv and look under the transmission .
Nov 18, 2017 | 2003 Ford Escape
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
What's your problem? wont move forward or back
Go to youtube . Type in your make and model/ forward and reverse will not engage. Should be helpful.
Dec 14, 2017 | John Deere 22HP Hydrostatic 42" Riding...
Hi, I was working with the snowblower and suddenly it stoped moving forward and backword. how can i resolve this. jamie
ok....ummm...lol...(What we are going to do is check the "THROW".of the "shifting lever" ( the FWD*NEUTRAL*REVERSE LEVER(handle)).....""Look at your linkage"" ...if it is a solid rod that connects the "shifting lever" with the transmission (make it go thingy), often times down near the transmission (where the rod goes to from the "shifting lever"))there is a short slotted bar that rocks back and forth on a "pinion" (rocking thing) .... look where the long rod (from the lever) connects to the short "rocking" arm (from transmission)and see if it has slipped...this will sometimes show by a shiny spot where the rod used to be fastened...simply loosen lock-nut and reposition where it used to be..then re-tighten....(we are trying to increase how far the short rod moves when you change gears from Forward to Reverse)......on some models this same rocking motion is adjusted up on top by where the "shift lever" is..look on the under-side of the "shift lever"..(which is attached to a "mounting" plate that connects to the handles together) that is mounted on a "pinion" bracket ) and sometimes there is a slot under side of the shift lever ...here there could also be a shiny spot where the rod used to be attached..reposition where it used to be..or move until sufficient "THROW" is acheived to shift gears from forward to reverse......""IF"" it is a "housed cable" that attaches the "shift lever" to the "transmission"..then there may be a broken or loose "bracket"..or a "return spring" on the bottom that has come loose or fallen off...If these options dont help..then it may be the "engage"..or "clutch " that has issues...a little deeper problem... (if you print this answer and read it "while" looking at snowblower and touch the parts that i physically desribe when they are mentioned it will be much less confusing...mechanicking is difficult to explain...kind of a hands on thing...) hope this helps a little..let me know if i can further assist..if I have at all... and ..all machines are different..lol...so the parts that i explained may not even be present...so much for uniformity!!!...lol...thanks for listening...Todd
Nov 23, 2010 | Garden
Lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Craftsman Garden
Transmission will not go into reverse. Sometimes it will and sometimes it will not. Drives well drive and reverse once in gear.
It sounds like the shift lever is out of adjustment by a small amount. Try moving the shift lever a little bit forward & backward from it's normal position to see if this is the case.
Mar 24, 2010 | 1993 Nissan Maxima
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
