Question about KitchenAid Dishwashers
Kitchenaid dishwasher model kudi23hbo - I am trying to remove water pump. Need instruction sheet.
hotuna
  • 288 Answers
SOURCE: kitchenaid dishwasher - water standing at end of cycle
How much water are we talking about? If its say less than 2-3 cups, It may be the way it is plumbed to drain. The drain line is back washing a little after everything is finished.
Posted on Dec 03, 2007
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
aborcass
  • 2651 Answers
SOURCE: kitchenaid dishwasher kudp01 pump problem
holding the center nut for lack of better word and unscrewing the wash arm, the next piece will require turning clockwise while pulling up on the plastic lock tab holding to up spout for water supply, gives you access ot 5 torx screws, after that theres 2 more torx screws giving you access to the chopper/ impeller area, thats as far as youll be able to go.
Posted on Mar 18, 2008
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
aborcass
  • 2651 Answers
SOURCE: Remove the Impeller on the motor of dishwasher
you can acess the impeller, by removing the lower spray arm, ther are 5 torx scrws holding the motor cover down, then from ther ther are 2 additional torx 15 screws covering the pump outlet and impeller housing, the impeller is spring loaded in place.
Posted on May 18, 2010
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
Dishwasher not cleaning
Remove the panel at the base of unit below door you should find the tech sheet which will tell you how to place unit into diagnostic, on the spray arms make sure the small holes are clean below the lower spray arm is a screen make sure it is clean not covered or cake with calcium build up if it clogged water cannot pass thru to enter the wash pump you can also remove the screws to take the upper halve apart to inspect the wash pump for any obstruction it is possible you could have a bad motor control or both you didn't mention after the unit fills do you hear the wash pump hum or click
Feb 07, 2014 | KitchenAid 24 in. KUDK02CRBS Stainless...
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
My kitchenaid kudv24 will not drain water out
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 21, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
My dishwasher is filled with water and won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 07, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
I have this model dishwasher and last year I spent close to $300.00 having this control panel replaced and as soon as the warranty went p it stopped working again, but there is a green light that blinks...
Sorry to hear about the trouble with service. I have put together a sheet to show why the clean light blinks and how to reset the control so you can use it. Let me know if you have questions I would be happy to assist. Here is the link to the instructions.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 06, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Kitchenaid dishwasher kuds24sewh2. It won't drain
  • A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
  • Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
  • Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
  • Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
May 04, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
Kitchenaid dishwasher model kuds01
you have a water heating problem. there is a tech sheet taped to the inside of the toe plate
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Water is not coming out of the top water jets for dishwasher
What is the model of this KitchenAid diswasher and approximatly how old is it? On some newer, energy saving models water is alternated from lower to upper spray arms. But ...
Remove filter that is in the sump area beneath the lower dish rack. Screws will need to be removed to open the area up. Look for blockages and clean filter.
Reassemble and test. If problems remain, it is probably a failing pump motor and will require a service call.
Mar 30, 2009 | KitchenAid Dishwashers
Dishwashers Logo
59 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
