Question about Jl Audio 8W0 Car Speaker
One of my jl's does not work i have power to it but it does nothin is it blow
  • 959 Answers
Yes , if it has power to it... and it is not functioning... it is blown.
Posted on Oct 06, 2010
I have installed a 12" w7 and jl 1000/1 v2 amp. I was useing the bass knob untill i found out on the jl website that its not needed for this set up. I was haveing problems blowing 80 amp fuses so i went...
It is NEVER a good idea to increase the values of fuses . Chances are you have internally damaged your amp. The next time you are faced with this problem you need to find out why your amp is blowing fuses and not keep changing the value of the fuse.
Aug 20, 2010 | Jl Audio 12W7 Car Subwoofer
I have a jl audio slash 500/1 series amp, and it keeps blowing the fuse. am i using the right one? which one should i be using?
if its the fuse in the fuse link then you should be using the a 50A fuse thats if on your amp there is fuses that total 60A when you add it up and if it still blows then you might have a short in the power wire between the battery and the 50A fuse
Aug 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
The power light comes on then it give out
jl audio 12w7 with jl audio 1000.1
get a high volt capacitor 8 or more fared a breaker fuse 100amp .Best bet is to have an another battery hook up in back of truck for this kinda set up cause this amp really pulls alot of juice
May 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Dust cover came off of cone on a older JL W3.now it blows alot of air.
The dust cover does not need the flexibility needed at the outer edges of the cone. Clear nail polish often works well for dust covers.
Oct 30, 2009 | Jl Audio 12W3 Car Subwoofer
Had power cut now machine wont work changed the fuse still nothin
check power from the wall socket if its ok the doorlocks and motors are prone to blowing the circut board can be expensive
Jul 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Most power out of amp w/out blowing subs
you may only be able to get but so much out of the subs. If you turn the bass down a little so the that you dont drive the subs so hard you may get a little more wattage out of them
Apr 06, 2009 | MTX Thunder 1501D Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Blown fuse
What size fuse are you using?
Have you checked the speaker to determine if it's damaged?
Do the speaker and amp produce clean sound up to the point where the fuse blows?
Aug 06, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Amp problem
you either have a bad ground or your power line is too small, the farther you go from the battery the larger wire you need.
Dec 18, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Blowing fuses
You will need to have the amp bench tested at full load to see if there is a pending problem. It will need to see with speaker loading resistors, how much current the amp is drawing and at different frequencies. if the amp checks out with the proper current, at the rated output, have the speaker checked out. Good Luck
Jun 15, 2007 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 8W0 Car Speaker Logo
22 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
