Question about TORK Variable Cycling Timer 8601
I have a TORK 1103.. I have read and re read all wiring diagrams..my problem is.. it now turns on.. but doesnt click off.. unless i manually do it myself.. Im pretty sure i have all the wires connected to the right places.. any suggestions?? Thank you..
Tork 1103 controls 2 loads
Your wiring is OK ... if the dial rotates and the tripper turns ON the load, then your wiring is correct
It sounds like you forgot to put the OFF trippers on dial?? Or the OFF trippers are worn out.
Dark trippers = OFF
Light trippers ON
Look at the trippers up close ... as they arrive at the manual override, they make contact with a mechanical lever ... the motor then pushes the dial forward and the trippers flip the manual override lever on-and-off.
Is the manual override broken? I doubt it.
Are the OFF trippers worn down?
Posted on Oct 07, 2010
Can a tork timer 1101 be used to control a 240 volt pool pump motor by controlling only 1 lead of the motor thus having the other lead hot all the time?
Yes: 240 volt can be controlled by turning off 1 hot leg of 240V circuit.
But the tork 101 clock motor still requires 120Volts (unless you buy a tork 240volt 201 clock motor to replace the 120volt 101)
Copy following links for handy resource and wiring diagram:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/images/Tork-1101-wired-to-control-240.jpg
In the wiring diagram above, it shows white neutral wire running to Tork 1101 timer terminal 2. Bring this white neutral wire from any nearby 120volt outlet.
In event that you do not have this white neutral wire, you can connect ground wire to terminal 2 and that will give 120volts to the 101 clock motor.
Completing circuit to clock motor using ground wire is violation of national electric code for many reasons, however the tiny clock motor only draws 3 watts, and you will remember to bring a white neutral wire to this timer at later date so you can sleep better at night.
Additional resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
Aug 27, 2013 | Hardware & Accessories
An electrician installed a new Tork 1103 24 hr timer for the pool pump. You can only manually turn it on and off. When trying to set the time, the dial is loose and does not stay in position and does not...
I think you have 120Volt pool pump.
Add a comment if this is incorrect since wiring information is based on this assumption.
(1) Wiring problem:
Evidence shows timer is wired in reverse (dial only rotates when pump is ON, and dial stops rotating when pool pump is OFF)
Electrician reversed the wires, but wires need to be tested.
Hot wire from circuit breaker always connects to L
Neutral wire from breaker box connects to unmarked terminal.
This will give clock motor continuous power.
Next:
Black wire going to Load (pump) connects to X
White wire going to Load connects to unmarked terminal along with Neutral wire.
Tork 1103 is SPDT timer with 3 watt 120volt clock motor that can control multiple loads and voltages, and can be wired many different ways.
http://waterheatertimer.org/pdf/1103INSTALLOP.pdf
(2) Loose dial. The dial should only rotate counterclockwise when moved with hand. The fact that trippers work when rotated by hand says dial is probably not problem. If timer is used, and trippers skip over and do not turn on Load (pump) then order P47 replacement trippers.
http://waterheatertimer.org/images/Tork-1102-3-500.jpg
Aug 07, 2011 | Hardware & Accessories
Tork 1104 is wired 120 vac. hot wire connected to L with jumper wire to 1.hot wire for outdoor lights connected to X. nuetral wires are wire nutted together. not connected to timer. clock not working....
The clock isn't working because the Tork 1104 clock motor requires 240 volts. Jumping the 120 volts over from terminal L to terminal 1 doesn't make it 240 volts. You need another 120 volt leg (180 degrees out of phase) to do that. The Tork 1103 timer is what you need, or change the 1104 clock motor to a 120 volt.
Dec 16, 2010 | Hardware & Accessories
How to wire a 1104 series time switch
8896f6e.jpgTork 1100 series
Tork 1103 can control 120V or 240V Loads (fan light motor)
It can control 1 or 2 different Loads
Tork 1103 has 5 screw terminals
L 1 Unmarked X 2
The Tork 1103 has a 120V clock motor that consumes 3 Watts and costs $3.50 per year to operate.
1) You have to have a white Neutral wire from breaker box connected to Unmarked terminal no matter if you are controlling 120V or 240V Load
2) You have to have a black Hot wire from breaker connected to terminal L no matter what load
If you have 1 Load 120V:
Terminal L black hot from breaker
Terminal 1 no wire
Unmarked terminal white neutral from breaker
Terminal X black wire going to Load
Terminal 2 no wire
White wire going to Load connects to Unmarked terminal
So 2 white wires are on terminal 2
If you have 2 Loads 120V (Load1 Load2)
Terminal 1 jumper your black hot from Terminal 1
Terminal X black wire going to Load1
White wire going to Load1 connects to Unmarked terminal
Terminal 2 black wire going to Load2
White wire from Load2 connects to Unmarked terminal
So 3 white wires are on terminal 2
If you have 2 Loads 240V
Unmarked terminal white neutral from breaker (no other wires connect to this terminal)
White wire going to Load1 connects back to 240V breaker
White wire from Load2 connects back to 240V breaker
If you have more questions, add a comment and I will help
Oct 30, 2010 | TORK Variable Cycling Timer 8601
I have a 110 Pool Pump and I am trying to wire it into a Tork1103NC timer. From the pool pump I have a black, white and green wire that I need to wire into the timer. Can you tell me what position those...
Here is Tork 1103 wired for single load.
1) The green pump wire and bare copper wire go to green ground screw
2) Pump black wire goes to pole 2, the NO (normally open) pole
3) Pump white wire goes to unmarked screw
4) Black from circuit breaker goes to pole L
The T1103 comes with a removable brass bar that connects pole L and pole 1
If that removable brass bar is not there, then add a jumper between pole L and pole 1 as shown in diagram above
5) White neutral from breaker box goes to unmarked pole (all whites connect to unmarked pole)
In your case, pole X is not used. Pole X is NC or normally closed > which means the power is ON continuously until timer turns on, and when timer turns ON, the NC pole turns OFF
Oct 11, 2010 | TORK Variable Cycling Timer 8601
I have a Tork 1103 24 hour time switch and I need directions on understanding the wiring diagram.
I assume this is the wiring diagram you have for your timer. I don't know what you're trying to control with this timer, but it has a 110V timer motor so it must have a neutral conductor connected. The L terminal would be your incoming line conductor (hot, usually black) The X terminal would be your Load terminal (usually black too) The unmarked terminal would be your neutral conductor. The incoming and outgoing neutral conductor would be connected here (usually white) If you're using this for 220V load, the hot conductor would be connected to the terminal marked 1 and it's load connected to the 2 terminal. Or you could use it for two separate circuits4591020.jpg
Aug 13, 2010 | TORK Variable Cycling Timer 8601
Not sure how to wire my Tork 1103 timer
The L terminal would be for your "hot" incoming black wire. The X terminal would be for your load outgoing black wire. Connect both white neutral wires to the blank terminal (notice this feeds the timer motor. The other two terminals (1&2) are not necessary if it is a 110V single circuit.
Aug 03, 2010 | TORK Digital Interval Timer Ssa100r-24
I have a tork 1103 electromechanical switch. its working but wont
T1103 can be wired many ways.
T1103 has 240V clock motor.
You are connecting 240Volt pool pump to timer.
Open link below and see wiring diagram: look at bottom left diagram:
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
Electricians don't guess, they test.
Turn power off and separate wires for testing.
Tape tester leads to wood sticks to keep hands away from power.
Stand on dry boards. Wear dry clothes.
Do not touch anything metal.
Turn power ON.
Test each wire to bare ground wire.
For 240V circuit, two different wires should light up tester. Working from your description, by code, these wires should be black and red.
Each of these wires is Hot wire.
These are called Line wires, wires going to pump are called Load wires.
Hot wires connect to terminals L and 1. This will power the clock motor and dial will rotate as time passes, assuming clock motor is good.
Hots are identified.
Test one of the hot wires to remaining wire, and not to bare ground.
Tester lights up on Neutral wire. This should be white wire.
Double check that Neutral wire did not light up on bare ground.
Neutral is not connected to any 1103 terminal.
Remaining wires go to Load (pool pump).
By code, assuming Hot Lines are Red and Black, the Red & Black Load wires connect to X terminal and 2 terminal, in either order. One wire on each terminal.
White wire connects to Neutral wire and is covered with wire nut.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jul 15, 2010 | TORK Digital Interval Timer Ssa100r-24
Timer keeps time, but sticks at tripper points
1) Clock motor needs replacement:
Link below shows timer and wiring manuals.
2) 120Volt Clock motor sells for $43 at Frontier lighting
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
3) New Tork 1103 sells for $55. Just swap out insides without changing box.
4) Intermatic crossover for Tork 1103 shows Intermatic T103 timer.
Amazon sells T103 for $50
http://www.amazon.com/Intermatic-T103-120-Volt-Mechanical-Switch/dp/B000LDIDBY
Oct 01, 2009 | TORK Digital Interval Timer Ssa100r-24
Tork timer 1103 will not trip off unless lever is
The timer should have came with a dark and light colored tabs. they must be put exactly on the rail that goes in a circle with the time on it.
Apr 12, 2009 | TORK Digital Interval Timer Ssa100r-24
TORK  Variable Cycling Timer 8601 Logo
195 people viewed this question
Top TORK Hardware & Accessories Experts
 Kenneth
Kenneth
rgbypoet
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
