Question about Garden
I own a GBG power 2000 pressure washer and I cannot get it to run. It will hum for 3 seconds and then trip the reset.
  • 4,336 Answers
Release the trigger pressure to allow for start up. Sounds like motor jambed by pressure build up. After motor is running it should be okay.
Posted on Oct 06, 2010
  • Van Blades
    Van Blades May 28, 2014
    mine will run for about 10 min. and then trips the reset switch and then I wait about 8 min and can push the reset switch and it will work again for about 10 min. continues this act as long as I am patient.
Pressure washer won't run
motor is seized or rusted
Jun 29, 2015 | Electric Garden
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Husky pressure washer is tripping my circuit
throw it away and go by another one...
Nov 03, 2013 | Garden
I have an ingersoll-rand ss5 that intermittenly hums and trips the breaker at start up. I replaced the check valve could a pressure switch cause this to happen?
Hope I can help you. When you say intermittently hums and trips from start-up. Is this when the receiver tank is empty, or up to pressure?
One of the first thing to try, you seem to have done, it is usually the check valve which can cause this.
The second thing to check would be the capacitor, but you say you have replaced the motor, was the motor AND the capacitor replaced at the same time?
By what you describe it does sound like a power problem, the pressure switch shouldn't be the cause of the humming. (The pressure switch simply tells it to switch on when the pressure is low, and to shut off when it is up to pressure)
Do you have any other power tools or equipment plugged into the same system? It may be that you might not have enough power to run all your machines?
Finally, do you have your compressor plugged into an extension lead? Vital power can be lost doing this, if so, and if you can, plug it straight into the power socket and try that.
Kind Regards
Carl
Oct 04, 2012 | Ingersoll Air Tools & Compressors
I own a GBG 2000 pressure washer and I cannot get it to run. It just hums and then after 3 seconds, kicks off the reset button. What do I need to do?
Don't know this model intimately but it looks similar to the Karcher which is really total **** nowadays as its all made of plastic. The motor has a weird switch mechanism but if it tries to run and the motor doesn't then 100:1 the motor is seized. Very unlikely it's the actual motor but the pump is a "swash" plate that opens 3 stainless steel thin flat valves. the bearing that the pump shaft goes through is a phospher-bronze plain bush with a seal each side and if this has dried out then you are screwed. Same if you model has steel roller bearings. However, if it does run and build up pressure and it stops because the output pressure is too high then the overload pressure switch is faulty. If it is the Karcher type then again you are stuffed but if it is similar to the Nilfisk then a replacement is available for around £100 GB Pounds - probably cheaper to buy a new one.
Oct 06, 2010 | Garden
Will not run
buy a gas powered they last 10 times longer.
Jun 13, 2009 | Garden
Karcher electric press. wash. Hums when turned on then trips bre
Dear K_mccurdy,
I am assuming that your washer is single phase. A comon reason for humming is a faulty capacitor. This must be changed by a new one.
Now one must see why the capacitor got damaged. This could happen, when the gun is closed the machine starts and goes off again in short intervals. In this case a control valve, often called the Spill Valve, needs lubrication or replacement. I prefer to replace it. Even if the pump has no faults and you have a habbit of closing and opening the gun more than necessary...the capacitor will get damaged. It is also important that if you use soap or chemicals, always rinse with fresh water before storing away the washer. Also never store the washer with pressure still built up. Always release the gun, before storing. Well in your case it must be the capacitor. If the capacitor is OK or you have changed it....try the washer without load. This can be done by removing the gun. You can leave the water supply, for this has a cooling effect during this test. Things should work fine now. If not...then the electric motor must be checked. But I repeat...the most common fault for humming is a faulty capacitor.
Regards,
Fulltech.
May 06, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
225 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
