Question about Moen Plumbing
I have extremely low pressure from my Moen Posi-Temp 1222 shower valve, but otherwise it functions well. Should I replace the posi-temp cartrige?
  • 26 Answers
Hi Ken--
Positemp cartdiges should deliver years of maintenance free operation. Usually, clogs develope downstream from the cartridge. If the cartridge still works well, that is, if it still pulls and turns freely, and the rest of the house has decent water pressure, check your shower head. Remove the head and test the water pressure. If the water flows better without it, you may have a clogged shower head. Over time, rust and scale can build up inside the shower head and block what would otherwise be decent water pressure. If a visual inspection does not yield any visible blockage, you can consider cleaning the head by soaking it in a calcium removing solution such as CLR. This often helps, but my preference is to replace the shower head completely.
--Hope this helps.
Posted on Oct 07, 2010
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
Low hot water pressure on Moen Single-Handle Shower Only posi-temp shower control. Cold water pressure is fine. Hot water pressure elsewhere in house is ok. Cold it be the cartrige -- lime buidlup, etc.?
I think you are on the right track. The first thing I would do is change the cartridge. While you have the valve apart examine the inlet ports as good as you can to see if there is any mineral buildup. You can use a short length of a small gauge mallable wire to run into water ports to se if you can break anything loose. Another thing you can do is to turn supply stop on slightly while you have the valve disassembled to wash any particles out. Hope this helps you and thanks.
May 14, 2011 | Moen Posi-Temp Single HandleTub And Shower...
Low water pressure. New installation, replacement
posi temp's usually have shut off valve's to the left and right of center.remove trim plate and check,make sure they are turned full on.i am pretty sure they are quarter turn type,and they have a screw driver slot,when there horizontal they should be fully open
May 09, 2010 | Moen Posi-Temp Single HandleTub And Shower...
The posi temp valve has a little system built inside to anti scald you when your taking a shower, they have little parts that move back and forth, they get easily clogged from sediment and minerals in the water and always get stirred up when the water is turned off and back on from doing work.
Mar 17, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have a single handle shower valve by Moen. Water is slowly leaking past the valve when shut off. I got the handle off but need to know how to further disassemble so I can replace whatever seal or o-ring...
there is a clip holding the cartridge in place. You need to remove that and then there is a little plastic throw away tool that comes with a new cartridge that you use to break the seals loose on the old cartridge....then you use a pair of channel locks to grab the stem and pull it out. The new cartridge should come with detailed instructions.
If it is a moentrol valve...the part number is 1225 and if it is a posi-temp it is a 1222. Moentrol you pull out to turn on and then left and right for temp adjustment. Posi-temp just turns to turn on and you turn from cold to hot to adjust through the temp range.
Dec 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
How do you replace the cartridge on a moen posi temp faucet?
remove the handle, then there is a u shaped clip you will need to pull....then you can get the cartridge out. I suggest getting the cartridge first....it comes with a toll that will be useful in removal plus some directions. The cartridge number is 1222
Oct 24, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Leaky posi temp shower valve
coming from the uk it sounds that when you mention it leaks at night its a possibility thats when the water pressure increases & the valve starts to drip?
i know its not a solution but it may help you understand why its dripping at night.
Also the seals might be damaged in which case thats why its dripping check them for damage. make sure when you put the new cartridge in that you put some silicone grease around the seals as this helps the insertion & helps protect the seals from damage.
Kindly
Richie
Dec 15, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Plumbing Logo
380 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
