Service Manual for a RCA RS2302 compact audio system.
5 Suggested Answers
  • 489 Answers
SOURCE: need manaul for rca rs2302
http://www.manualsonline.com/ex/thread/view/idThread/2125767
pls check it out
Posted on Oct 11, 2009
fieldy14
  • 456 Answers
SOURCE: Using iphone ipod with compact audio system.
If your audio unit has an audio input plug and an auxillary function, you should be able to run the 3.5mm jack from the headphones socket on your iphone to the audio input of your audio system, then select aux on the audio system and you should be able to hear any music played on your iphone through your audio unit. Good luck.
Posted on Jun 07, 2010
Geeke
  • 41 Answers
SOURCE: I need a user manual
here you go
http://www.retrevo.com/support/RCA-RS2657-manual/id/19240dj985/t/2/
Posted on Mar 01, 2011
I have an RCA RP-8530 compact audio system and the CD player will not open. I seems stuck. Any suggestions on how to repair?
There may be a CD stuck inside or the eject mechanism may be weak or failed. Disassembly may be required to solve the problem.
Feb 15, 2015 | RCA Audio Players & Recorders
I was wanting to know what kind of burned dvds it will play
it plays with no problem : CDR,CDRW,DVD+/-R,DVD+/-RW,Audio mpe 3,Compact Disk Audio(CDDA),Video Compact Disk(VCD),DVD Audio,Dolby digital track,JPEG pictures
Jan 09, 2011 | RCA RTD120 System
RCA RS2603 digital audio system stopped playing CD's. Double cassette tape deck works as does radio, but cannot play CDs.
chack and see what type of CD you are using. i have been having the same issue. i actually found out that the CD's i use to play songs, and etc are "CD-R". the compatible CD's for my (RCA DIGITAL AUDIO SYSTEM RS2603) sterio are CD-RW's or compact disc that you find on production music like albums, etc. hope this helped !
Jan 03, 2011 | RCA RS2046 Shelf System
Need manaul for rca rs2302
pls check it out
Oct 11, 2009 | RCA RS2302 CD Shelf System
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
SONY DAV - S880 compact AV system
Sony.com may have a pdf downloadable manual available on line.
The standard way to connect Audio from a Receiver to a TV is to send a signal from the Tape outputs (RED & WHITE) on receiver via RCA cable to a Aux input (RED & WHITE) on the TV. Likewise, sending a Video signal from a receiver to a TV, is via a Co-Axial RCA cable , using a Video Out (YELLOW) on the receiver to a Aux Video Input (YELLOW) on the TV. An S-Video cable can also be used (in leu of yellow RCA cable) if available on both Receiver & TV.
Jun 10, 2008 | Sony DAV-S880 System
Now audio output
you can get a service manual for about $5.50 from here, http://www.asm-service-manual.com/List/RCA%20List%20ASM.htm
Oct 09, 2007 | RCA RS2625 CD Shelf System
No CD
hi yes, 2 options: find the hole that the door pushes when its closed... its a small hole in one of the corners inside the hole there is a small switch or theres a small lever that the door pushes when its closed push something that will push it permanently (a piece of paper, glue it with superglue, be creative...) good luck
Feb 20, 2006 | RCA RS2302 CD Shelf System
54 people viewed this question
 Grubhead
Grubhead
