Question about NetGear ProSafe GS748AT 48-Port Gigabit Ethernet Switch (GS748AT-100NAS)
Wht happens when you press reset? - NetGear ProSafe GS748AT 48-Port Gigabit Ethernet Switch (GS748AT-100NAS)
Heyy.. my phone (sumsung galaxy s3 ) wont go pass the sumsung galaxy s3 gt 19300 screen .. pls help me what should i do .. my phone is like my life.. yours faithally..?
First check if th phn has fallen frm ur hands or updated firmware via 3G or wifi or th sweat gets accumulated on th phn while talking causes it either freeze or touch sensation stops working so plz tell wht has actually happened nd also wht have u tried nd wht exactly shows on th screen
Nov 12, 2014 | Samsung Galaxy S3
Reset eeebox pc
  • Turn on your Eee pc
  • Continuously press F9 until a screen comes up with three options.
  • The third will be 'reset to factory settings.
  • This will delete all data and reset your eee pc.
  • Press down until it is highlighted then press enter.
  • It will tell you what it is about to do and ask you to type yes to continue.
  • Type in 'yes' - no capital letters
  • It will reset your Eee pc and ask you to press enter to reboot.
Your eee pc will then reboot and ask you for a name and password and all that stuff it asked you to do when you got it.
Aug 10, 2012 | ASUS Eee Box EBXB202-WHT-E0002 Intel Atom...
My genx digital mp4 player model no GMP4-02 got stuck on the welcome screen wht to do ?, plz help me
Fid a RESET button and press to reset it, and it will work fine again. Moreover after reset dot forget to format.
Thanks
Oct 11, 2011 | Audio Players & Recorders
I have downloaded some themes from internet and transfered them to my mobile nokia 5310 via bluetooth. Sudenly my phone memory was just 34 kb left. i formated my memory card deleted some data from phone....
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
  • Enter the code: *#7370# and press Yes to confirm initialization.
    • Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
  • To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
  • on/off + * + 3
    • Before making a Hard reset better backup all your important information: contacts , memo...etc
Oct 06, 2010 | Nokia 5130 Cellular Phone
I have problen in nokia n95 .... when i switched it on it start .. but when i press any of it button... it switched off immidiately... every time this happened... wht i do??????
This problem is caused by Viruses use a good anti virus and update it regularly....
First you need to format your phone take out memmory card from it,save important contacts and files to pc,
Then full charge battery and switch off mobile then press and hold these keys Call + * +3 then switch on mobile(Dont unhold Call + * +3 this keys for 2 minutes) then your phone got Hard reset and see the problem solved.Or your keypad ic got fried replace it by taking the mobile to authorised service centre.Thanks
Jul 30, 2010 | Nokia N95 Cellular Phone
Tower powers up great,but monitor has no signal
1st if the monitor light is yello and as soon as u switch on the comp,or if the monitor goes to sleep even though u ave checked the connection wht u need to do is u need to reset the graphic card if u ave a add on card and then clean the slot check for any damage or moisture and then put it back and reboot.i m working for hp ave got lots of those cases
'2nd wht u can do is press space bar and slightly tap the power button of comp seeif tht helps.let me know wht happened and in detail
Aug 25, 2009 | Compaq Presario 5000 PC Desktop
Wht is the master reset of may phone nokia N91
it 0000 or u can in this 00000000 or 12345
Mar 03, 2009 | Nokia N91 Cellular Phone
Getting error c630 on a kycera mita1525
Hello sir; C630 require reset, procedure as follow;
1, press these key by order and keep holding down.
2 these keys are "stop/reset", "start", "left copy density"
3, press "stop/reset" key again.
4, enter 163, press start.
5, window will show out "CLE"
6, press start to clear.
7, press "stop/reset"key and 001 to exit.
Jan 27, 2009 | Kyocera KM-1510 Copier
Sansa m250 headphone problem
hello :
Enter to restore the unit to the default factory settings. Press Select to confirm. Press Power/Menu to cancel.
dont forget rating this post if this is not helping u tell me so i can help u further .
Jul 12, 2008 | SanDisk Sansa m250 MP3 Player
P6SET-ML question
You're just lucky I happened to be doing some surfing today, AND the I happened to have one of these in my "spares" pile. :-)
From the top down:
grn -> wht = power switch
x -- x
blu -> wht = reset switch
red -> wht = HD led
x -- x
x -- x
x -- x
x -- blk = speaker
wht -- ^ = (speaker)
^ -- ^ = (speaker)
grn -- red = speaker
= power LED
And for the official word...
Here's a site I found:
http://www.elhvb.com/mobokive/Archive/Ecs%20-%20Elitegroup/manual/index.html
Here's the manual you want:
http://www.elhvb.com/mobokive/Archive/Ecs%20-%20Elitegroup/manual/p6setml.zip
The pin assignments are on page 20 of "Chap2.pdf".
Happy new year, and all that stuff!
Dec 26, 2007 | EliteGroup P6SET-ML Motherboard
NetGear ProSafe GS748AT 48-Port Gigabit Ethernet Switch (GS748AT-100NAS) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
