Question about Refrigerators
Is a refrigerator usually plugged in to a GFI outlet?
  • kk1887 Oct 06, 2010
    My cheap apartment building has my fridge wired to a GFI, and it spontaneously tripped when I was out of town (there was nothing that I did to overload it and everything was fine when I left). All of my food spoiled because of it, which wasn't discovered until I returned 2 weeks later. I'm considering filing suit against my landlord for negligence possibly due to faulty wiring.
  • 262 Answers
It is not good practice to use refrigerator on a GFI. it is not that it wont work but every time a gfi trips it is degraded. GFI can also be daisy chained up to 4 other plugs can be conneced to it if the electrician wired it that way.
A refrigerator is suppos to be on a dedicated circut.
Posted on Oct 06, 2010
    So a refrigerator is always supposed to be on it's own dedicated circuit? If it's connected to multiple outlets, would that be considered wrong wiring?
  • Donald  Rowan
    Donald Rowan Oct 06, 2010
    No.... you will need to check city electric code for your area and see if a GFI is required or not.
    but it is not bad wiring. your GFI could have triped for many reasons.
    you could have a problem with the refrigerator.
    you could have had a power surge.
    The GFI could have just went bad
    I have seen this happen many times and we just don't recomend a GFI on the Refrigerator.
Wow hope you talked to your landlord first or I wouldn't want you for a tenant. No a frig should not be plugged into a GFI which is otherwise a safety feature in the kitchen. Communicate with your landlord . Is there another outlet the frig should be plugged into? Otherwise request a repair and a resonable credit for the food loss. Jane
Posted on Oct 15, 2010
  • 1 more comment
  • kk1887 Oct 15, 2010
    Of course I talked to my landlord, but their version of repairing the refrigerator was pressing the "reset" button on another GFI outlet that the fridge is connected to. They also refused to give me credit for any food but said it's more of a renter's insurance issue, which I completely disagree with since the outlet tripped spontaneously while I was out of town.
  • jpsullie Oct 17, 2010
    A conscientious landlord should check out the problem. Plug the frig. into another outlet not protected by a GFI. (if you trip the GFI all plugs after that circut will loose power also, so don' t plug it into one of those either) The outlet should be grounded and you should not use an extension cord. If the main breaker snaps you probably have a fault refrigerator. Also try plugging other appliances in the outlet protected by the GFI. If the GFI snaps it may need replacing and if it is the only place you can plug the refrig. in without using an extension cord I'd not replace it with another GFI protected circuit,which may or may not mean running a new circuit
    A conscientious landlord should check out the problem. Plug the frig. into another outlet not protected by a GFI. (if you trip the GFI all plugs after that circut will loose power also, so don' t plug it into one of those either) The outlet should be grounded and you should not use an extension cord. If the main breaker snaps you probably have a fault refrigerator. Also try plugging other appliances in the outlet protected by the GFI. If the GFI snaps it may need replacing and if it is the only place you can plug the refrig. in without using an extension cord I'd not replace it with another GFI protected circuit,which may or may not mean running a new circuit .
Used Beverage-air MT27, trips GFI breaker when I plug it in. I tried to isolate the short - unlplugged the top light ballast, switch, fans... The guy I got it from says to be sure to connect the ground...
I've seen refrigerators that are working fine blow GFI outlets when the compressor starts, usually just change to non GFI outlet for fix. You say its tripping GFI breaker , is there anyway to test it on non GFI breaker?
Jun 24, 2011 | Beverage-Air MT27 Beverage Cooler...
My refrigerator keeps tripping my gfi out let.
This is a problem I have encountered before. When compressors start they sometimes trip gfi. Plug unit in different outlet or replace GFI with regular outlet
Jun 22, 2011 | GE Refrigerators
Refrigerator has electrical short causing GCI outlet breaker to pop. Is this an easy or cost prohibitive fix?
It is possible you have a short. However, the more likely cause is the simple fact the refrigerator is plugged into the GFI outlet. Try this first, take a heavy duty three prong extension cord, NOT a lamp extension cord, plug it into a non GFI outlet, and plug the fridge into the cord. Does it trip your house circuit breaker? If so, then you do have a short. You will need to call a local refrigerator repair company to find the source of the short, and only then will you know if its an easy or cost prohibitive fix. If it does not, and it likely wont, the problem is that a GFI outlet detects a fault to ground. Due to the humidity and moisture inside a refrigerator, and normal water drainage sometimes into the metal base of the refrigerator, it is not uncommon for water to contact metal points inside and outside a refrigerator. Since all / most metal points on a refrigerator are grounded to each other, if water contacts any of them, they can and will trip a GFI outlet breaker, because it is detecting a fault to ground.
Nov 09, 2010 | GALAXY Microsystems 63702 Top Freezer...
Is a refrigerator usually plugged in to a GFI outlet that's connected to multiple other outlets? Is it mere poor practice or should it never be done?
A GFI outlet (Ground Fault Interrupt) is actually designed to provide extra protection from electrocution in wet areas where water can come into contact with a hot wire, and as long as the refrigerator is plugged directly into the GFI outlet and is not plugged into the GFI outlet by using any extension cord then there should not be any problem as long as the GFI outlet is not over-loaded with other appliances or large electrical demands. If the GFI outlet is tripping then either there is a faulty appliance or electrical device plugged into the GFI outlet or the GFI outlet is simply over-loaded with too much electrical demand, or the GFI breaker could be faulty. Plugging a refrigerator into a GFI outlet is not bad practice, however over-loading one is and that is what should never be done.
Oct 06, 2010 | Frigidaire Refrigerators
GFI switch outlet may have damaged Kenmore 55771 side-by-side?
Could be the GFI switch.
The washer has a 3-prong (grounded) plug, what about the other appliances that you tested?
The GFI may not have a good ground and the 3-prong appliance provided a "difference" that the GFI detected as a "fault".
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
It keeps tripping a GFI outlet
GFI outlets tend to wear out very quickly with a refrigerator running on them,most Manufacturers do not recommend plugging any major appliance into a GFI outlet.If you plug it into a non GFI outlet and it works fine the problem is in the outlet.
Sep 06, 2009 | Refrigerators
Ge side by side refrigerator trips GFI
Try an extension cord to get it off the GFI outlet .
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
232 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
